Inductrix FPV BNF - Horizon Hobby's Tiny Whoop - RC Groups
This thread is privately moderated by CoasttoCoast, who may elect to delete unwanted replies.
Sep 21, 2016, 05:21 PM
Trader Rating: 1
CoastToCoastDrones
$99.99 USD
Seller Pays Shipping
Sold
These are looking to be shipped around 9/24/16 according to our rep. We will ship within 2 days!
If you want to pre-order one please PM me and we can send a PayPal invoice. Once it comes in then we will ship out within 2 days. If your worried about paying and not receiving, don't! PayPal protects you as a buyer.
Features
Back to Top ^
Intuitive flight modes that make flying simple
Fully integrated FPV flight camera on 5.8GHz
Quiet EDF power system
Improved motors for better response
Durable rotor housings prevent damage
Lightweight and fully-assembled with no building required
40ch 4.3" monitor with mount
E-flite® 200mAh 45C Li-Po flight battery and USB charger (included)
Overview
Back to Top ^
When Jesse Perkins first flew the Inductrix® quadcopter, he knew that there was more to the experience yet to be unlocked. He mounted a small FPV camera and video transmitter, upgraded the motors, found a better battery and called it the Tiny Whoop™. Soon, thousands of Inductrix owners were flying in places they never thought possible! The Inductrix FPV provides the freedom of flight in a fully ready-to-fly package. No soldering or 3D printing required! Enjoy a world you never knew existed when you are in the pilot's seat of the Inductrix FPV!
The Inductrix® FPV from Blade® builds on the wildly popular platform and transforms it into an incredible FPV machine right out of the box. With its integrated 25mW video transmitter, FPV camera, high performance motors and large 200mAh battery, the Inductrix FPV is capable of flying in the smallest of places with ease. Enjoy the view as SAFE® technology makes flying simple and while the ducted propeller design allows you to bounce of walls and objects without crashing! Not only does the Inductrix FPV come out of the box with everything installed on the aircraft itself you get a 4.3” FPV monitor (RTF only) that completes the entire FPV experience! If you are looking for that immersive goggle experience, the headset adaptor can be purchased separately too!
SAFE® equipped
SAFE (Sensor Assisted Flight Envelope) technology is a revolutionary electronic flight envelope protection system. This technology allows anyone to pick up the transmitter, put on the goggles and be successful flying FPV for the very first time. Its newly improved Stability mode allows for fast forward flight with the added weight of the FPV system. It prevents over controlling the aircraft and gives a confident feeling when maneuvering through tight spaces. The Agility mode has also been tuned for the high output motors and weight of the FPV system on board. It allows for aggressive forward flight and even some mild aerobatics.
FPV equipped
The Inductrix FPV is equipped with a 25mW video transmitter capable of transmitter on Fat Shark channels 1 through 7 and all Raceband channels so you can race several pilots at once. You can select channels from the easy to use button atop the body of the Inductrix. The camera is very lightweight and perfectly protected in the body housing. The antenna we’ve chosen for video transmission is a dipole and designed with durability in mind. Video range of the Inductrix FPV is nearly 100 yards line of sight and more than adequate to fly in any large building or home.
High Performance Motors
We’ve tweaked the flight controller to better control in stability mode by allowing pitch to remain as the user demands even if throttle is full and agility mode is more crisp and controllable too!
200 mAh battery
Included is a large capacity 200 mAh battery so that you can fly upwards of 4 minutes.
NO 4.3” FPV Monitor Included on BNF
The included FPV monitor is a 4.3” Spektrum (SPMVM430) and is the perfect solution for FPV without having to pony up the cost of a full goggle system. The monitor is rechargeable via micro USB and has a 1.5hr run time before it needs to recharge. It is capable of receiving on 40 channels and can be clipped on to the MLP4 radio for hands free operation.
The best part about the included monitor is that you can upgrade it to the full headset with the headset adaptor. This gives you an inexpensive way to have the immersive experience of a full goggle.
LED Lighting
With brilliant white and red LED lighting illuminating each Inductrix FPV, it’s easy to follow friends while flying together or even see if the battery is getting low when they begin to blink. The lights are mounted inside each frame so they too will be protected in a crash.
Quiet Ducted Fans
Each rotor is housed in a true duct and is extremely quiet during flight. The benefit of using ducted fans instead of propellers is they fully protect the fans in a crash and prevents the Inductrix from causing any damage to walls and is safe enough to be caught by hand!
Tech Notes
Back to Top ^
You will need...
Nothing! Everything you need to get flying is included in the box
Specifications
Back to Top ^
Type: Multi-Rotor
Gross Weight: 24g
Length: 83mm
Kit/ARF/RTF: RTF
Experience Level: Beginner
Recommended Environment: Indoor
Is Assembly Required: No
PM me if interested!
Sep 22, 2016, 07:09 AM
Trader Rating: 137
How are you shipping? USPS priority etc?
Latest blog entry: Hubsan H107D Custom FPV Setup
Sep 22, 2016, 01:29 PM
Trader Rating: 0
anybody have an idea about whats under the hood of this badboy? will we be able to mod the boards?
Sep 22, 2016, 10:51 PM
Trader Rating: 1
CoastToCoastDrones
UPS most likely
Sep 24, 2016, 09:24 AM
Trader Rating: 26
Farmer
f.a.r.m.e.r's Avatar
im sure you can throw a bee frsky board in there or bee spektrum board on there, in the parts listing it shows 2 different fpv systems one is the inductrix 25mw vtx with seperate camera for indutri 200 and the other one looks like the same vtx and camera from the blade nano qx both with dipoles which i think is etter than the tin clovers that dont even work worth a damn and tuned verywell and bend and break the pdb where the antenna is attached.
saw it on hh website parts listing, also lots of flavors in canopy covers which is cool but no adjustable camera tilt
Sold Inductrix FPV BNF - Horizon's Hobby's Tiny Whoop CoasttoCoast Aircraft - Electric - Multirotor (FS/W) 2 Sep 10, 2016 09:45 PM
Sold Pre-Order - Inductrix FPV BNF - Horizon's Hobby's Tiny Whoop CoasttoCoast Aircraft - Electric - Multirotor (FS/W) 1 Sep 02, 2016 04:32 PM
Sold Pre-Order - Inductrix FPV BNF - Horizon's Hobby's Tiny Whoop CoasttoCoast Aircraft - Electric - Multirotor (FS/W) 18 Aug 28, 2016 04:05 AM
