This thread is privately moderated by 1000MPH, who may elect to delete unwanted replies.
Sep 20, 2016, 12:44 PM
Objects in mirror are losing
1000MPH's Avatar
Gyro Bee Build
I need a replacement for my Gyro Bee that I killed a few months ago.
I'm trying very hard to build this one simple, cheap and lightish.
Target weight is 30oz.
Build Specs:
Bee II cores
Std Hitec servos: HS 425's.
4 cell AA Sanyo Flat pack.
upgrade to .25" Fiberglass rod to replace the std carbon tube spar
.080" fg rod arched I-beam in stock location.
5mm x 1mm carbon ribbon sub TE spar.
Strapping tape: approx 2 full layers of standard 3" Bee tape.
thinned goop
spackle used sparingly
Oversized 2mm coroplast winglets
balsa wingtips (not winglets)
Orange Gyro/Rec'r
Sep 21, 2016, 04:32 PM
1000MPH's Avatar
Wing was 18oz before strapping tape.
2 full layers of strapping tape: 24.3oz.
Here's a pic of the bottom, looks better in person.
Sep 27, 2016, 07:20 AM
1000MPH's Avatar
Bottom is covered with Hobby King covering. I'm not a fan of this strapping tape, it wrinkles when ironed . I think this build will keep me from using it for awhile.
Oct 03, 2016, 12:36 PM
1000MPH's Avatar
Sidetracked by a sloping adventure to Castle Peak/Castle Ridge.
The top of the wing is covered with solid blue HK covering, I'm going to add a fluoro red Monokote stripe to each wing for orientation.
Oct 04, 2016, 10:37 AM
1000MPH's Avatar
Added a couple of stripes on top.
Elevons are up next. I'll be using different balsa stock (1-1/2" x 1/4") and will bag with fiberglass.
Oct 08, 2016, 08:46 AM
1000MPH's Avatar
Bagging a couple sets of elevons. Hoping these turn out on the light side.
Oct 09, 2016, 04:09 PM
1000MPH's Avatar
Thin goop before covering the elevons.
Oct 11, 2016, 07:28 AM
1000MPH's Avatar
For a comparison, I decided to bag a set of elevons using the supplied thinner balsa.
Oct 18, 2016, 10:55 AM
1000MPH's Avatar
Just finishing up...
Elevons hinged
Pushrods re-attached and control horns mounted.
Double-checking gyro settings.
Oct 19, 2016, 10:42 AM
1000MPH's Avatar
Winglets installed.
Getting heavy and it will need nose weight.
Oct 19, 2016, 10:59 AM
1000MPH's Avatar
Initial Gyro settings...
Radio: Spektrum DX6i
Acro/Heli: Acro
Wing/tail mix: normal (no elevon mixing )
Reverse: Aileron
Rates:
Elevator: 40%-80%
Aileron: 50%-80%
Flap/Gyro switch operates Gyro on/off and throttle-elevator trim mix
Gyro:
Aux: on (rev)
E-Servo: on (rev)
A-Servo: on (rev)
Delta: on (rev)
Pots:
Yaw: off
Pitch: 25%
Roll: 50%
Nov 24, 2016, 05:10 PM
1000MPH's Avatar
Gyro Bee was maidened on Monday. Only needed a few clicks of down trim. Really happy with the way it flew but I did mess around with the gains. I got it to oscillate a bit but still flew excellent.
This one's a winner.
Dec 23, 2016, 04:27 PM
1000MPH's Avatar
I took a pic on the rock at Weldon. Final AUW: 33.5oz
Dec 30, 2016, 12:03 PM
1000MPH's Avatar
2 quick vids DSing the top spot at Parker.
Gyro Bee DS at top of Parker (1 min 10 sec)
Gyro Bee DS at top of Parker (part 2) (1 min 5 sec)
Jan 15, 2017, 12:26 AM
1000MPH's Avatar
Decided to replace the Orange with a Lemon....gyro that is...
Setup on the gyro was almost the same as the Orange. The only change needed was to flip a servo from reverse to normal on the TX.
The gyro on/off is on ch 5 instead of ch 6.
Adjustable gain is on ch 8 so that's not available with my cheapo DX6i.
Unfortunately, test flights will have to wait until next month.
The manual for the lemon, found here is excellent.
