Sep 14, 2016, 06:21 PM
What do you think of this fpv system?
hi
So, my questions are:
(see below for hardware list)
1. Am I forgetting something? Is everything compatible?
2. On what component should I best spent a little bit more to have the most improvement in the image/*range?
3. Are there better components for the same or slightly higher price?
4. What range could I expect?
5. Is there anything I should know of the format it can transmit?
E.g. let’s say I’m recording 1080p HD on the camera itself, and I want to transmit 800*480 pix (to amount of pixels of my monitor), is this possible? Is there a limit to av out in terms of resolution or frame rate? E.g. possible to transmit 2k video?
I made this list of components to build my fpv system:
AOMWAY 5.8G 3dBi RP-SMA Male Four Lobe RHCP VTx/VRx FPV Antenna
http://www.banggood.com/AOMWAY-5_8G-...-p-978264.html
€ 13.46
ImmersionRC Raceband 5.8GHz 25mW AV Transmitter Module for FatShark
http://www.banggood.com/ImmersionRC-...p-1020626.html
€ 30.74
30MM FPV Cable for Git1 Git2 Git Camera support AV Out Charging
http://www.banggood.com/30MM-FPV-Cab...p-1049201.html
€ 4.15
Eachine LCD5800D 5.8G 40CH 7 Inch HD FPV Monitor with DVR Built-in Battery
http://www.banggood.com/Eachine-LCD5...p-1067081.html
€ 63.27
In addition:
I own a gitup git2 13g lens camera (AV and RAW output) and a walkera g-2d gimbal mounted under a custum build drone. My transmitter for flight control (spektrum dx6i) works on 2.4 Ghz, so I guess I will have to go for a 5.8 Ghz video transmitter system.
I guess I need:
screen because it's cheaper than goggles and I can still see the drone in the air (just my preference)
5.8 Ghzvideo transmitter/receiver
some av out cables with micro/mini usb power connector
two good antennas, both probably Circular Polarized Omni Directional Antennas for the 5.8 Ghz frequency. Apparently antennas have a huge impact on your range and quality
Thanks for the recommendations!
babi
