Spektrum SR2100 DSMR Antenna-less Micro Receiver
This all-new design saves space and improves RF signal in RC vehicles
Save Space and Improve RF Performance
Improved RF performance is one of the features of the new SR2100, says Spektrum. This space-saving micro receiver ditches the traditional wire antenna in favor of an internal PCB antenna. The Spektrum SR2100 DSMR receiver is a 3-channel design, and features waterproof Reliakote conformal coating that "seals its electronics from the elements and other corrosives like nitro methane or motor spray."
CLICK HERE for more info on the all new Spektrum SR2100 DSMR receiver
Features:
  • Built-in antenna
  • DSMR protocol
  • 3-channel functionallity
  • 5.5ms frame rate with very low latency and super high speed response
  • Small and lightweight
  • Reliakote coating protects the SR2100 from water, fuel, and dust
Sep 13, 2016, 05:09 PM
Fan of just about anything RC
SoloProFan's Avatar
Nice design. Just missing one important spec, the range.
Latest blog entry: For the love of the hobby!
Sep 13, 2016, 07:39 PM
KE Spins make me dizzy.
Looks like almost an exact copy of Airtronics' line of receivers.
Sep 14, 2016, 09:52 PM
Looks great. Now why does it have to cost more than $30? I have no idea the price. Just know it's too much.
Sep 14, 2016, 11:57 PM
SoloProFan's Avatar
They can no longer earn money on broken antenna and receivers that get replaced because of that, so they need to facture in the loss in revenue in the price of the antenna-less receiver, maybe?
Sep 15, 2016, 12:04 PM
Considering that the sr2000 was $99, this isn't bad. As for the range, if you buy a cheap rx don't expect it to go a mile. If you spend a bit more, it will be just fine. I use a sr2000 for speed runs and it goes as far as the eye can see.
Dec 29, 2016, 01:38 AM
wkderf's Avatar
why the hell has this been pushed back to a June 2017 release?!
Dec 29, 2016, 06:47 AM
SoloProFan's Avatar
That's odd indeed. Maybe some issues were revealed, and for once, it was decided to not let the customer be the guinea pig to discover these?
Jan 02, 2017, 01:51 AM
wkderf's Avatar
That would certainly be a welcome change. For one thing, I'd like to see an additional connection slot available on the receiver.
For the vast majority of on-readers, they use 4 connections on their receiver:
Throttle / ESC
Steering Servo
Motor Fan
Transponder
As it is, this receiver only has 3, so that leaves the need to use a Y harness, or run the fan straight off the battery, which isn't great for the long term life of the fan.
Jan 03, 2017, 10:43 PM
Cookie
10x8's Avatar
Awesome news. Great for Spektrum users like rcdog and Bill 'Yes Man' Delong.
Jan 04, 2017, 07:30 AM
Brake Weight's Avatar
It looks to be the same size as the normal receivers it just has half the board turn on a 90* angle. So it has a smaller 'footprint'. I remove the case on my micro builds and put on a large piece of heat shrink for protection.
