Sep 12, 2016, 11:04 AM
Car Bashing
Jym73's Avatar
Mini-Review
Remo Hobby - 1/16 4WD Monster Truck - Review
Remo Hobby - Rockect Smax - 1/16 4WD Monster truck
I received a RH 1/16 4WD MT from TMART.com to do a review.
Remo hobby website : RH 1/16 4WD Smax Monster truck
There is a coupon code "REMO10" who give 10$ discount.
Photos :
Name: RH - rocket smax - front size view.jpg
Description: Name: RH - rocket smax - front .jpg
Description:
Name: RH - rocket smax - chassis above.jpg
Description: Name: RH - rocket smax - chassis right side.jpg
Description:
Name: RH - rocket smax - chassis under.jpg
Description:
Unboxing :
• REMO HOBBY - ROCKET Smax 1/16 4WD - Unboxing • (12 min 12 sec)
Specifications :
Scale : 1/16
Lenght : 283mm
Width : 220mm
Height : 120mm
Wheels : 37 Width : Diameter : 77mm
ESC : 2 in 1 receiver/esc with 5 wires plug, 3 wires plug, light plug.
Battery : 1500mah li-ion.
Transmitter : 2.4Ghz, 4 x LR6/AA batteries (not included)
Transsmission : steel gears on ball bearing with gear differential.
Servo size : 35mm x 28.5mm x 15mm.
Size comparison :
Name: RH - rocket smax - size comparison.jpg
Description:
From left to right : HBX 1/12 sct, Huanqi 1/16 buggy, RH 1/16 Monster truck, WLtoys K929 1/18
Spares provided :
Name: RH - rocket smax - spares.jpg
Description:
Provided with : 1 steel spur gear, 4 body shell clips, 1 allen 1.5mm, 1 allen 2mm. 1 "tamiya like" plastic wrench.
Parts inspection :
Wheel :
Name: RH - rocket smax - wheel disassembled.jpg
Description:
Rim is in 3 parts assembled with 5 screws.
As we can see there is foam in tires.
Suspension :
A-arm :
Name: RH - rocket smax - suspension.jpg
Description:
The 4 a-arms are identical.
Shock absorber :
Name: RH - rocket smax - shock absorber disassembled.jpg
Description:
Can't be filled with oil. 70mm from hole to hole.
Shock tower :
Name: RH - rocket smax - shock tower.jpg
Description:
Front and rear shock tower are identical. 3 holes position for shock absorber.
Rear hub carrier :
Name: RH - rocket smax - rear hub carrier.jpg
Description:
Transmission :
Overview on chassis :
Name: RH - rocket smax - transmission overview.jpg
Description:
Gearbox are molded in chassis and upper deck.
As we can see spur gear mounted on the car is made with plastic.
Transmission out of the chassis :
Name: RH - rocket smax - transmission out of chassis.jpg
Description:
Center drive shaft is made with plastic.
We can see the spare spur gear, metal.
Name: RH - rocket smax - transmission - soft center drive shaft.jpg
Description:
Center drive shaft is very flexible.
Differential :
Name: RH - rocket smax - differential opened.jpg
Description:
All gears are made with alloy.
2 spiders.
Motor :
Name: RH - rocket smax - quick access to motor pinion.jpg
Description:
Motor pinion quick access.
Motor mount :
Name: RH - rocket smax - motor mount.jpg
Description:
Motor position not adjustable., 3 motor's position.
Wheel axle and drive shaft :
Name: RH - rocket smax - wheel axle and dog bone.jpg
Description:
Steel wheel axle and drive shaft.
11.8mm hex hub.
2x8.5mm pin.
drive shaft :
- Overall lenght : 60mm.
- Ball diameter : 5mm.
- Pin : 2mm x 9.
Steering system and servo :
Name: RH - rocket smax - steering and servo.jpg
Description:
Soft servo saver.
Servo : 35mm x 28mm x 15mm.
Others parts :
Front bumper :
Name: RH - rocket smax - front bumper .jpg
Description:
Electronics :
ESC :
Name: RH - rocket smax - esc.jpg
Description:
- Waterproofed.
- 2 in 1 receiver/esc.
- 5 wires plug for servo
- 3 wires plug (JR) for servo.
- 1 small plug for light.
Transmitter :
Size comparison :
Name: RH - rocket smax - transmitter size coparison.jpg
Description:
A little bit big but not heavy.
Left hand steering wheel position
Name: RH - rocket smax - transmitter left hand.jpg
Description:
Parameters :
Name: RH - rocket smax - transmitter parameters.jpg
Description:
- Throttle dual rates.
- Steering dual rates.
- Throttle trim.
- Steering trim.
- Steering reverse.
- Light on/off switch.
Battery charger :
Name: RH - rocket smax - charger .jpg
Description:
2s-3s charger. 3X 800ma.
First thought :
- Well built.
- Seems solid.
- Soft plastic will surely prevent from breakage.
- Chassis flexibility will maybe change gears mesh.
- Many parameter on transmitter who allow to slow down the car also, good for very young kids.
- Light system available (5 volt).
- 3 wires JR plug allow to use a more standard servo.
- Waterproof esc will allow to use it in wet environment.
- Standrad Dean/T connector is a good thing.
- 12mm hex hub allow to use 1/10 wheels.
- Motor pinion is 0.7m, not very standard size, but as motor position isn't adjustable, we can't change motor pinion size., 3 motor's position.
- To remove motor or access differential we must remove 50% of the parts (upper deck).
- I'm not sure it can reach 50km/h, i guess more than 30km/h, will see with speed test.
Videos :
Speed test :
• REMO HOBBY - ROCKET Smax 1/16 4WD - Speed test • (16 min 44 sec)
- Works pretty nice.
- Steer very quick on asphalt.
- Rear bottoming out a lot.
Feel free to ask any questions
More to come , stay tuned
Sep 12, 2016, 03:43 PM
Deleted post
Sep 12, 2016, 03:46 PM
Car Bashing
Jym73's Avatar
By shipping
This car is already available in few webshops.
Sep 12, 2016, 05:21 PM
Yeah sorry, I thought it was from that other supplier that asked for volunteers then I saw the logo bottom right of your screen grab after I posted my original comment. So you lucky bugger, your getting two samples but different versions. Nice. (I'll pm you my address for when you are finished reviewing the sct )
Sep 13, 2016, 10:57 AM
Car Bashing
Jym73's Avatar
, i will be able to compare both chassis.
Sep 13, 2016, 11:16 PM
looks really nice.
tiny clone of xmaxx.
Sep 14, 2016, 12:15 AM
Car Bashing
Jym73's Avatar
Yes, i like its look.
Sep 19, 2016, 05:24 PM
JohnVHRC
JohnVH's Avatar
edited
Sep 19, 2016, 07:59 PM
Jym, is that coupon at BG or Tmart?
Also, how do you see this coping with a brushless upgrade?
Sep 20, 2016, 12:13 AM
Car Bashing
Jym73's Avatar
It is a Tmart coupon .
The very soft center drive shaft can be an issue with brushless motor imo. From what i can see on remo hobby website there should be a metal upgrade, but i don't know if it will be available.
Sep 20, 2016, 02:05 AM
That seems a nice RC!
The driveline looks similar to the a979!, like the spurgear, I wonder if a steel a979 spur would fit?
What I would do is add some oil shocks and fabricate an aluminium plate under the chassis, the this little rc would almost be perfect!
I think the metal gears look great and are rather strong but when it is some kind of pot metal it probably will wear fast
I do love those tires!
Sep 20, 2016, 05:06 AM
Car Bashing
Jym73's Avatar
There is already a steel spur gear as spare provided with the car.
I will try to compare RH and WLtoys spur gear.
Shock will leak.
Yes, will see gear durability. But if the car is kept as stock i think it is durable.
Sep 20, 2016, 09:19 AM
Originally Posted by Jym73
ar.
Sock will leak.
Yeah but therefore you must get some oil shocks, I do believe the upgraded ones from the a979 will fit
Sep 20, 2016, 10:50 AM
Car Bashing
Jym73's Avatar
If they have 70mm from hole to hole, yes, it will fit.
Nov 29, 2016, 06:32 AM
biomecanoid's Avatar
Hi,
Can anyone please tell me what size pinion gear this truck uses what pitch and what size axle ?
Also is this truck trully 21cm wide ? Isnt this too wide for 1/16 scale ? My 1/12 scale car is about that wide too.
What size are the wheels ? Diameter and width ?
This car cames in 3 versions: buggy, monster truck and short course truck right ? Different body but inside the mechanics are the same correct ?
