Onepaa X2000 / Turnigy Eclipse WiFi 2K Action Camera for FPV with PWM control - Page 3 - RC Groups
Oct 05, 2016, 01:42 PM
TechTronic9000's Avatar
Originally Posted by nigel_
http://whois.domaintools.com/onepaa.com - look at the email addresses!
Brilliant
Latest blog entry: JJRC Q46 Speed Runner - Review
Oct 05, 2016, 01:51 PM
Pixelpeter's Avatar
So SJCam is joining the cloners? If you can't beat them, join them!
Oct 05, 2016, 01:57 PM
It's interesting that in SJ's product range there isn't any product similar with the X2000 so they are not cloning this, i refer to design and functionality.
Oct 05, 2016, 07:21 PM
Nigel_'s Avatar
Maybe it will work the other way around and SJ will clone the X2000, probably with a more decent image sensor. 4MP is a bit out of date now for anything but a very cheap action cam.
(It's still a decent sensor for a dashcam but not good for photos or even fake 4K, I guess it's actually a decent choice for FPV too for the same reasons it's good for dashcams.)
Originally Posted by Pixelpeter
Quite surprised not more people are interested in this camera as it seems like a really nice one with a gyro that seems to work pretty good; although the cradle isn't an original find (but still very handy!) the wifi dongle is a smart solution imo. Only thing I'm really missing is some influence on image parameters like contrast, saturation, white balance and sharpness otherwise I might have gotten one already
If you are just using it for FPV then the gyro isn't required and maybe not wanted. If you want great video and aerial photos then it has the wrong sensor. I guess there is enough choice of well known FPV cameras that people aren't looking too hard for alternatives from unknown brands. Still zero customer reviews on GB.
Must be some people who would like it because of the transmitter though, that could be used nicely in many situations other than aircraft where wifi range is inadequate.
Oct 06, 2016, 06:36 AM
For fluent 1080p @ 60fps, the CMOS resolution is sufficient, it even has enough free space for gyro operation and indeed this configuration is used on some great performing dash cameras, as for direct FPV feed with gyro, indeed it's not advisable as it will take away the sense of aircraft's movement, but for a slower glider plane it's OK and smoothness out pilot's "acrobatic maneuvers".
Oct 07, 2016, 11:08 PM
CrocEnd's Avatar
Mine got payed 4 today, Now the waite
Cheer's Croc
Oct 08, 2016, 08:26 AM
Cheer's Croc
Looking forward to your experience with it
Nov 07, 2016, 05:18 AM
OnePaa X2000 + FXT cradle as full FPV and recording setup on my XK A1200 plane doing acrobatics
Video settings:
2K@30 fps
Gyro: ON
FOV: narrow
Edited and resized to Full HD 1920x1080p
XK A1200 - 3D Acrobatics, Loops, Rolls, Dives and Low Passes (3 min 0 sec)
Nov 12, 2016, 08:24 PM
mmormota's Avatar
The hdmi output is working during recording? What is the latency on the hdmi output? Most important modes for my application are 720p30fps and 720p60fps mode on hdmi output. (I am searching for a small but good camera for FPV using digital HD transmission.)
Nov 15, 2016, 03:00 AM
I will test and report back, the only thing is that beside my TV i don't have a hdmi capable device and from what I know it has a 35-45 ms lag on HDMI input. Hopping this weekend to lag test the OnePaa.
Nov 15, 2016, 09:35 AM
mmormota's Avatar
Thank you very much.
Nov 25, 2016, 12:30 PM
Sorry for the delay, I'm having some heath issues, I hope this weekend i'll be able to do the test.
Nov 28, 2016, 11:30 AM
I have did the following combinations:
720p@30fps - only video out
720p@60fps - only video out
720p@30fps - recording
720p@60fps - recording
1080p@60fps - only video out
1080p@60fps - recording
In all of the above cases through HDMI on my TV i get around 200ms
Later edit
I will try another time also the analog output
Nov 28, 2016, 11:47 AM
mmormota's Avatar
Thank you very much for the test. These data are important as more and more digital transmission systems are available, and hdmi is the usual input.
Nov 29, 2016, 03:29 AM
What digital transmitter are you planing to use ?
