Sep 11, 2016, 04:57 AM
Question
Advice UMX P-51 BL or UMX P-47 BL
Hi guys, I have flown the Champ and UMX T-28. The motor in my T-28 stopped working and flying this plane became a little boring. Now it's time for a new plane. I have a hard time with choosing between the UMX P-51 and P-47.
My preferences:
- Belly landings on grass.
- At least twice as fast as UMX T-28.
- Able to slow flight.
- More stable in wind.
Which of the two do you recommend? I think the P-51 would be too fast for me, but at the same time I don't want to get bored with the P-47 too quickly
Sep 11, 2016, 05:23 AM
ɹǝʎןℲ ǝıssn∀
taz101's Avatar
My preferences:
You might have more response in the Micro area!!
Here..........https://www.rcgroups.com/micro-ready-to-fly-420/
LURCH
Latest blog entry: Compulsory Reading!!
Sep 11, 2016, 11:07 AM
The P-51 is better streamlined and has a more powerful motor than the P-47. The P-51 can fly fairly slowly and it flies fast only when you push the throttle up. The AS3X keeps both airplanes stable in wind but the additional power in the P-51 motor allows it to be able to fly in higher wind than the P-47. Hint, get the P-51.
Sep 11, 2016, 02:07 PM
Ya I am in the market for a new UMX and I was wondering the same thing. I was leaning towards the P-51 so good to know its a good flyer.
Sep 11, 2016, 05:12 PM
Also read that a lower kv motor, makes the motor stronger, is this true?
Sep 11, 2016, 09:12 PM
chulian1819's Avatar
looking at the specs, they have the same engine but the P47 weights more and produces more drag with the radial engine
Sep 11, 2016, 09:54 PM
circle flyer
slow and low's Avatar
I think "stronger" is used correctly, more torque is probably a better term. A motor of the same size with more torque can turn a larger or higher pitch prop. These smaller, lighter planes really don't need more torque and a higher RPM motor often is a better choice which gives more top end speed at the expense of less torque.
Sep 17, 2016, 04:10 PM
Which of these two is better in slow flight?
Sep 17, 2016, 09:30 PM
No, the motors are different.
The P-47 has the weaker 2500kv motor also used in the UMX Carbon Cub and the P-51 has the more powerful 3000kV motor also used in the UMX Yak and UMX Pitts.
Sep 18, 2016, 12:44 AM
http://www.sgvhumane.org/
cmdl's Avatar
You cannot claim the 2500kv is weaker unless you know the actual current limit. All you know is that it can swing a higher diameter/pitch/number of blades prop than the 3000kv, assuming the same weight.
Power = current x voltage. You do not know what the current limits for the two motors are.
Sep 18, 2016, 08:50 AM
circle flyer
More torque is favored over speed for slow flight, but there is not that much difference between the two motors. Use what you have.
Sep 18, 2016, 02:12 PM
microheli's Avatar
There is a significant difference the 3000kv motor have more speed and more torque with the given props. Flight times may be shorter to the higher power consumption.
Oct 06, 2016, 05:18 AM
mattman0182's Avatar
The Jug is on sale at hobbyzone.com for just $99.
Personally that is enough to finalize my decision. However I hate P51s so that wasn't an issue anyway.
99 bucks seems like a great deal for a BL plane with the HH track record of great customer service. Just think, it's the same price now as the standard brushed P51.
Buy the jug!!!
https://www.hobbyzone.com/specials/t.../EFLU3250.html
Oct 06, 2016, 04:02 PM
DFS#000178
Rampage's Avatar
I remember reading a while back that despite the radial housing the P-47 is less draggy than the P-51. And that's why it performed so well despite being so large.
IMO, of the two, the P-47 is way sexier. It flies great too. Especially on 3S. Flies fast, flies slow.
Oct 06, 2016, 08:08 PM
I always found P51 to be ugly.
The razor back 47 looks so sexy.
plus that silly belly scoop on the 51 could create issues on belly landing
