SPAD Race Boise Idaho - RC Groups
Sep 10, 2016, 10:44 PM
Faster is Better
Slopemaster's Avatar
Today we had a SPAD pylon race hosted by BARKS, Boise Idaho.
It was a lot of fun with a good turnout and perfect weather.
Latest blog entry: LEG Fat Albert Take 2
Sep 11, 2016, 02:22 PM
Thanks Ken! We had a great day with folks traveling from all over Eastern and southern Idaho to attend. Looking forward to our 8th year of 2 pylon SPAD racing in the new year
Mar 28, 2017, 12:38 PM
what engine did you used on this plane ?
where i can find plan of this plane ?
any video
thanks
Mar 28, 2017, 02:34 PM
DPS racers
Yep, Das Plastics!! We allow the fuselage to rotate 180 degrees, and we cut the spars down to 7/8 in tall. We also can rotate the motor, and put all servos inside cleaning up the air frames. Most guys run dual aileron servos too.
We can run the OS 55ax or the ASP/Magnum .52 XLS with the baffles removed from the mufflers of all engines, on 10x8 APC sport props, and 15% nitro fuel.
Speed test put them in the 93-96 mph at around 14,300 rpms. Both motors are pretty close, with a very slight edge to the ASP or magnums running just a bit higher rpms.
We have to meet sound at one of the flying fields, and cant exceed 96 db at 9 feet from more than 1 of the 4 cardinal compass points, and the above setup just makes it. Other prop brands like master aircrew fail the db meter, and are slower, even scimitars.
We run 2 pylons set 400 feet apart. We typically run 4 pilots per heat, 5-6 total heat races that are 10 laps long. At 2 of the sites, the top 4 fastest qualifiers go to the trophy race, and that race is 15 laps and the top 3 get trophies or plaques. Can come real close on a 6 ounce tank with ASP and Magnums, OS is a little more fuel efficient.
At BARKS, we run our races Reno style: 4 pilots per heat, 6 heats at 10 laps, and then we take the top 4 fastest to go for 15 lap trophy races in Gold, next 4 go to Silver, then next 4 to Bronze trophies races. We then hand out trophies or plaques to the top 3 in each trophy round, so 9 folks go home with something in hand for their efforts. Man is it ever fun!!!
Mar 28, 2017, 02:39 PM
SPAD race video
This is video from 4 yrs ago, we used to launch and mill like boat racers do, but have found the staggered 2x2 launch to be better now, just like they do in regular pylon 424 or 426 racing. But you can see the speeds they are capable of getting on. Not too bad for a cheap plane I'd say.
SPAD races with a crashat 00:59 (4 min 10 sec)
Mar 28, 2017, 02:46 PM
another race at Idaho Falls
Another heat race at Idaho Falls 4yrs ago. Our racers age range from 14 to 84! Fun for everybody, of all abilities
SPAD races #1 (3 min 4 sec)
Mar 28, 2017, 04:40 PM
Faster is Better
Thanks Brian.
Aug 27, 2017, 01:24 PM
Faster is Better
The BARKS club of Boise, ID is hosting its annual SPAD race, September 9, 2017.
