Castle Telemetry X-Bus Spektrum issue
Hi, guys!
I've recently been playing with more telemetry options with my Spektrum DX-18 Stealth system. I have installed a Spektrum AR7350 receiver in a plane that I am also using modules for Airspeed, G-Meter and your Castle X-Bus telemetry link. I am using an CC Edge 80 ESC on a 5S power system with an E-Flight Power 46 motor. I DID update to the latest firmware with my Castle Link on the ESC and the X-Bus module. My issue is that while in flight, my telemetry voice call outs are reporting Amps that are obviously WAY too high and most likely are off by a factor of ten (decimal point). So I hear reports of Amps that are 160 - 450+ Amps! Any thoughts on why this is reporting this way? Is there a set up function I missed? |
Did you check the data log to see if the logger is recording the proper value?
Shoot tech support an email if you are still having trouble. Thanks very much. |
