Sep 09, 2016, 08:09 AM
Banggood Staff
Cool
【ONLY$49.99】【Last day】Flysky FS-i6S 2.4G 10CH AFHDS Transmitter With FS-iA6B Receiver
The link:
http://www.banggood.com/Flysky-FS-i6S-2_4G-6CH-AFHDS-Transmitter-With-FS-iA6B-Receiver-p-1024018.html
Mar 09, 2017, 11:50 AM
Death From Above
RabbitDFFD's Avatar
is this controller JUST for quad / multi rotor copters ? still fairly new to the hobby and looking for a transmitter that will work with all my aircraft. . drones and 6ch cp helis.
Jan 02, 2018, 01:42 PM
John Luciano's Avatar
Can it be used with servos like for a boat
Feb 15, 2018, 06:48 PM
rgburrill's Avatar
Sorry to take so long to answer. I just saw this.
I use mine in two sailboats. I got the Turnigy version and it came with 2 receivers, one for each boat. The iA5B has 6 servo connectors while the iA6C has an IBus output. You will need to get the IBus expander if you use the iA6C or IBus compatible servos.
Feb 15, 2018, 10:30 PM
I’m
Using just the receiver with my Debo 7-E
In a boat using rewired 40 year old Airtronic servos
Feb 17, 2018, 07:00 PM
rgburrill's Avatar
Watch the pinout on those Airtronic servos, they are different than Futaba. I think it is 5V and signal that are swapped.
I'm not familiar with the Debo 7-E so don't know if it is compatible with the AFDHS2.
Feb 17, 2018, 07:30 PM
Yes I switched Ground and + 5 the Debo 7-E worked with. the FlySky receiver ,
Feb 18, 2018, 01:58 PM
rgburrill's Avatar
Don't know what to tell you. I should work.
Feb 18, 2018, 03:07 PM
Works perfect. Now going to try and converts some old Hobby Shack servos
Feb 26, 2018, 08:43 PM
The old Hobyshack servo won't work ... I did get the speed control to work. Using a different battery for the reciever and the motor. Thanks guys ...
