Sep 08, 2016, 05:09 PM
No Guts, No Glory
timmybeetle's Avatar
Black Horse Spitfire MK IX 2000mm 33cc BH 136
Pilots
I bought this plane and I want to go fly with a GAS engine.
So anyone who has this plane you're welcome to give your opinion regarding this plane.
Winspan: 2.000mm 78.74inch
Length: 1.760mm 69.29 inch
Weight: 6.8Kg 14.96 lbs
Engine recomended by BH: OS GT 33CC GAS
Comes with air retracs, but I sold them I want electric and bought these from HK, All Metal Servoless 90 Degree Retract for Large Models (10~12kg) w/10mm Pin.
I will use leggs,wheels that came with plane.
Servo's:
Flaps, Aileron and Rudder: Corona DS339HV Digital Metal Gear Servo 5.1kg / 0.13sec / 32g
Elevator: BMS-621DMG+HS High Speed Digital Servo (Metal Gear)7.2kg / .10sec / 46.5g
Gas GWS standard servo.
Motor:
Update 26-1-2017 DLE 30 prop : Graupner 18 x 10
XMTR: Futaba 12FG
RCVR: Futaba R6014HS 14 channel
Flying weight: 8.5 Kg ( due to 1,1Kg lead to set CG right)
Static trust: 7.89 Kg
grts Hans
Sep 10, 2016, 02:35 PM
Prekin's Avatar
If I were you, I would use ROTO 25 or some 30cc engine (DLE 30).
I put DLE 30 into my Seagull 30 cc Spitfire (2030 mm). She has heavy tail in the video, so it wasnīt the best flight.
Seagull Spitfire 30cc maiden flight (3 min 17 sec)
Sep 15, 2016, 04:38 AM
No Guts, No Glory
fuselage
Hi pilots
Today I started with fuselage inspection.
All seems good, I will fly with gas engine so I coated inside fuse with Polyurethaan.
Will take my time to build me this nice plane.
grts Hans
Sep 16, 2016, 11:16 AM
Prekin's Avatar
Looks better than the Seagullīs one. Keep posting.
Sep 18, 2016, 04:26 PM
Spitfire.Willy's Avatar
I'm bilding the same plane, but mine wil fly with a electric motor.
Aerodrive C6374- 200 elektro motor.
10S 4500
YGE 120HV
Power HD 8309 TG servo's
Futaba T14
Oct 30, 2016, 08:11 AM
No Guts, No Glory
Retracts en Flap servo's installed
Pilotes
Retracts are installed, only remove some material and re mounted M3 bolts in wing to fit my HK retracts unit.
I used legs from KIT and needed to shorten them 5mm in order that wheel will fit into wing.
Flap servo's installed, I noticed that I had to reverse one servo so they go the same way, my servo's are smaller than standard and I was able to fit them into mount with some 5mm wood, see pics.
After glue adapters on flap I noticed that alignment wasn't right......ordered Ball Linkage to solve this issue.
grts
Oct 30, 2016, 09:50 AM
Prekin's Avatar
What are those gear legs?
Nov 04, 2016, 01:40 PM
No Guts, No Glory
spinner backplate
Spinner backplate is way out of balance.
I removed weight by drilling material .
Now in balance, cone is another story need some tool for my balancer to test this.
Also make decision about prop, 4 blade ore 3 blade ore 2 blade?????
grts
Nov 08, 2016, 01:32 PM
No Guts, No Glory
Flap alignement
Pilot's
My ball linkage arrived at only 8 days from china.
Because of alignement problem I solved this by using these ball linkage.
Picture tell's story I think
grts Hans
Jan 26, 2017, 02:33 AM
No Guts, No Glory
building again
Pilot's
Building again afther a while found some time to do more on this plane.
It's a ARF so it's just putting all in and adjusting servo's with XMTR.
Using a corona 14channel RCVR
I changed pilot by one from HK looks more real to me.
Pictures tell story
grts Hans
Jan 31, 2017, 06:53 AM
No Guts, No Glory
Motor
Pilots
I received my motor and started to mount it .
I had option 1 pitts exhaust and option 2 long exhaust.
I decided to go for long exhaust also this one reduced exhaust noise.
Cowl also ready and tested with prop and spinner, lloks good to me.
Only cooling of engine is tricky will see.
grts Hans
Feb 09, 2017, 10:23 AM
No Guts, No Glory
Motor propeller test
Pilots
Started with motor test and looking for prop.
1ste Biela 19x12 gives me 5400 Rpm and trust 4,5Kg
2de Biela 19 x 8 x 4 gives 4400 Rpm trust 4,5Kg
finaly Graupner 18 x 10 gives 6900 Rpm trust 6,5 Kg
Spitfire flying weight around 7,2 Kg
Update 10-02-2017
Checking my Cg at 100mm and it's tail heavy....!
I need 1100 gram lead to get CG right.
So that's a bummer, take off wight will increase with 1,1Kg making it 8,4 Kg.
grts Hans
Feb 11, 2017, 10:43 AM
No Guts, No Glory
Foto's after test run at home.
Pilots
Tested today my motor again,
After some adjustment I got max Rpm at 6900-7000.
Static trust 7.89 Kg.
Flying weight 8.4 Kg.
This for me is a good reading for enough power to fly this plane.
grts Hans
Feb 12, 2017, 09:09 AM
No Guts, No Glory
Almost ready for first flight
Pilots
Well build done.
Almost ready for first flight.
Will be in March/April.
Need my friend to film first flight.
till then I fly my Kyosho Spitfire
till later....
grts Hans
Feb 13, 2017, 01:59 PM
No Guts, No Glory
Test run with DLE 30
Pilots
First test with Biela 19 X12 only 5400Rpm, with Graupner 18 X10 Rpm 6900
Black Horse Spitfire DLE30 with Biela 19 X12 (0 min 53 sec)
DLE 30 idle run with graupner 18 X10 prop (0 min 21 sec)
grts Hans
