This thread is privately moderated by santanig5, who may elect to delete unwanted replies.
Sep 06, 2016, 08:29 AM
Ghost Rider the pattern's full
santanig5's Avatar
Build Log
E-Flite FJ-2 Fury 15 DF with EFLR310013 SAFE Rx
EDF Size: 69mm
Flaps: No
Flying Weight: 3.3 lb (1.49kg)
Length: 38.75 in (984mm)
Material: Z-Foam
Motor Size: BL15, 3700Kv
Recommended Fuel: Electric
Recommended Motor Battery: 14.8V 4S 3200mAh LiPo
Retracts: No
Servos:13g
Speed Control: 60-Amp (installed)
Wing Area: 304 sq in (19.6 sq dm)
Wingspan: 36.75 in (933mm)
Combined Ailerons with a wye cable, required to reverse left elevator servo. All other controls worked in the correct direction.
Also required an On/Off switch between ESC and Rx.
I changed the EC3 plug to a deans as all of my 4S batteries have them.
***UPDATE*** 9/8/16
Replaced Reversing wye cable with standard wye cable and used Turnigy in-line short reverser to reduce the size of the wire bundle.
YouTube Playlist
https://www.youtube.com/playlist?lis...3DG1rN7lEDrbyf
FJ 2 Fury Maiden (6 min 33 sec)
