Sep 02, 2016, 02:27 AM
Eachine Micro Skyhunter 780mm Fpv Airplane PNP With Camera
Not a bad Micro Skyhunter Kit from Eachine, preorder for $92.99 only.
http://www.banggood.com/Eachine-Micro-Skyhunter-780mm-Wingspan-EPO-FPV-RC-Airplane-PNP-With-Camera
Features:
Come with Eachine EF-01 AIO FPV Camera,five bands 40 channels with Raceband
Camera can be installed or removed,so you can switch the airplane between FPV airplane and normal airplane.
With adjustable metal camera bracket,can freely adjust camera angle.
Molded, White EPO foam
Super compact size for zipping through small places
PNP assembles in 30 minutes or less when hot glue is used
Easy to find CG with finger bumps under wings
2 Piece canopy for FPV gear with strong magnets
Simple, one handed launches - "Like throwing a small football"
Powerful, multirotor style motor with almost unlimited vertical (PNP)
Note:
- This is a PNP airplane,not including transmitter,receiver,battery or charger.
Description:
Brand Name: Eachine
Item Name: Micro Skyhunter
Wingspan: 780mm (31")
Length: 540mm (21")
Weight: 230g (without battery)
Color: White
Material: EPO
Camera: Eachine EF-01 AIO FPV camera
ESC: 20A 2-3s with XT60 connector
Motor: Eachine 2204 2300KV
Motor MAX Thrust:440g
Motor Weight: 25g
Motor Shaft Diameter: 3mm
​Propeller: 6x3, but works well with most 5-6" multirotor props, even quad blade.
Servos: 3x 9 gram
Recommended AUW: Under 375g
Specification Of Eachine EF-01 Camera:
Sensor: 1/3 "CMOS
Lens: M8 800TVL Lens
Angle: 150 FOV horizontal viewing angle of 170 DFOV diagonal perspective
Format: NTSC / PAL (switchable)
Resolution: NTSC: 960X480/ PAL:960X480
Power consumption: 380mA @ 3.7V
Power: 3.6-5.5V
Lens Mirror Diameter: 2.1mm IR coated FOV150 (horizontal)
Support video format: NTSC / PAL
Output Impedance: 75 Ohm
Output signal strength: 23 ~ 24dBm
Output Power: 25mW
Wireless Channel: 40CH
Antenna: RHCP circular polarization clover leaf antenna
Operating voltage: 3.6V ~ 5.5V
Current: 100mA
Audio carrier: 6.5MHz
Button function
Short press (Apr. 1 sec or less): Change channels 1-8
Long press (More than 1.5 sec): Change bands A-B-E-F-R
Long + press (More than 3 sec): Change NTSC/PAL system
NTSC or PAL (selectable; Blue LED on= NTSC; Blue LED off=PAL)
Weight: 8g
Size: 26x20x18mm (without antenna)
Sep 02, 2016, 06:38 AM
the same by RMRC: http://www.readymaderc.com/store/ind...oducts_id=5448
Sep 02, 2016, 07:53 AM
Yes, but this one comes with the camera and video transmitter, at cheaper price than RMRC
Sep 02, 2016, 08:23 AM
I void warranties
Yea but it's not black!
Sep 02, 2016, 09:08 AM
fly it high as possible
Yea, somebody ready to pay extra for the color, but,
in many cases white foam much more stronger than black.
Sep 02, 2016, 10:03 AM
Is it summer yet?
How does the color of the foam determine the strength?
Sent from my iPhone using Tapatalk
Sep 07, 2016, 09:58 PM
It now says "expected arrival 3 days" and it's 34% off for the next two days. I'm in for one at $69.99!!!
Sep 08, 2016, 04:00 AM
guyst's Avatar
It says in stock now - http://bit.ly/2cvmioX
Sep 08, 2016, 08:48 AM
Farmer
f.a.r.m.e.r's Avatar
Actually color means nothing, the biggest differences between these two is the ready made rc skyhunter is made out of EPP and the Eachine skyhunter is made out of EPO as a friend pointed out to me last night.
Best Regards
Farmer
Sep 08, 2016, 09:04 AM
dry your eyes and go fly
joe559's Avatar
Yeah......... what he ^ said
Sep 08, 2016, 09:41 AM
Farmer
Yeah that guy up there, He is the guilty one that informed me^^
Sep 09, 2016, 11:34 AM
Hmm... I do admit I really really wanted the black one, and I do feel a little guilty about not supporting RMRC. I figured I'd be irresponsible with this plane so cost won out this time. I'm also torn between one being EPP and the other EPO... I actually think EPP will be better if you're going to try to destroy it? Case in point- The Teksumo is EPP.
Here's a good video with a visual explanation between the two.
https://youtu.be/EJKZSoSeh7g?t=5
I just thought of a solution to my issues... I'll just have to BUY THEM BOTH!
Sep 09, 2016, 12:50 PM
65.00 shipped 7-9 days, I ordered one. Can't be that bad for the price.
Sep 15, 2016, 05:56 AM
Vids: YouTube.com/FyreSG
FyreSG's Avatar
I have one set with me now for review. While I have done a couple of plane reviews, I'm worried about lacking details that you'd like to know. Please let me know which aspects you'd like me to cover.
Sep 16, 2016, 05:02 AM
Could you please confirm it is EPO and not EPP ?
