Sep 08, 2004, 07:39 AM
DBa
DBa
French style flyin
DBa's Avatar
Jet Design Contest : Pusher Mirage 2000N
Hi all,
I'm a new e-zoner and i want to notify my entry in the JDC by building a little Dassault Mirage 2000N from this plan :
http://corsair.flugmodellbau.de/file...n/MIRAGE_2.ZIP
I reduced it for having a wingspan of 585mm and it will be powered by an AXI 22/08/20 or a mega 16/15/xx, I'm plannig to stay under a weight of 600Grs with a 3S1P 1500mah lipos.
Best regards, and good luck to all.
DB.
Sep 08, 2004, 07:53 AM
A jet "design" contest entry from a scaled down plan?!?
Am I missing something?
Bernie
Sep 08, 2004, 08:07 AM
DBa
DBa
French style flyin
DBa's Avatar
well i just keep the external lines from it cose it was made for an os 91 vrdf and made a lot of modification cose the plan doesn't keep enough material on some parts so i have redraw all the plan and design the jet for havin a little pusher motor and for cutting it with my router.
DBa.
Sep 08, 2004, 11:02 AM
EDF rules... :)
AirX's Avatar
WOF did it already using that plan for the Wemo minifan.
Cheers,
Eric B.
Sep 08, 2004, 02:12 PM
silkmoth's Avatar
He David,
I really hope to receive your pics but directly at home and have the project to copy that really nice French aircraft
A bientôt au terrain
jLuc
Sep 08, 2004, 02:29 PM
DBa
DBa
French style flyin
DBa's Avatar
ok j-luc je crois qu'il va y avoir de la course poursuite entre tes 29 et mon 2000 dans l'air.
DB
Sep 08, 2004, 04:32 PM
silkmoth's Avatar
Ho David,
en fait je t'ai répondu sur l'adresse email fourni par RC group mais elle paraît invalide du fait que j'ai eu deux fois un retour d'erreur. Mon email est [email protected]
Dès que j'ai ton adresse email, enfin une j'espère qui marche, je t'envoie mon message
Jluc
Sep 08, 2004, 06:38 PM
It looks pretty good.... i don't kno if it is a design though... cuz i mean everything was already there in the plan....
Sep 08, 2004, 07:23 PM
EDF rules... :)
AirX's Avatar
DBa,
Welcome to the E-zone and the Jet forum, I am posting a link that will help you enroll in the Design Contest, it is run by a member named "Arbo", check out the link and read the thread then PM Arbo to join in the fun...
https://www.rcgroups.com/forums/showthread.php?t=250724
Cheers,
Eric B.
Sep 10, 2004, 12:33 PM
DBa
DBa
French style flyin
DBa's Avatar
Thanks airx,
If u already done it, can i ask u how have it flown? and where i can find the CoG location?
Byes,
DB.
Sep 10, 2004, 01:38 PM
EDF rules... :)
AirX's Avatar
Another zoner goes by the name WOF did this last year from those plans but it was EDF. Look up his posts and you can find the build and possibly the CG in one of them.
Eric B.
Sep 10, 2004, 02:04 PM
DBa
DBa
French style flyin
DBa's Avatar
thanks again Airx.
Sep 17, 2004, 12:14 PM
DBa
DBa
French style flyin
DBa's Avatar
updating the construction.
Here's how i made the canopy:
designing the mold:
milling the mold :
putting fiberglass on it :
Sep 17, 2004, 12:22 PM
DBa
DBa
French style flyin
DBa's Avatar
Vaccum baging the mold :
And after a night :
24grs
Sep 17, 2004, 12:23 PM
DBa
DBa
French style flyin
DBa's Avatar
And after a few adjustement:
Whoops! jet design contest-EDF Mirage 2000b build thread Bryce From Nice Electric Ducted Fan Jet Talk 81 Jan 30, 2012 02:04 PM
Cool 04/05 Jet Design Contest Winners (Pusher) Arbo Pusher Prop Jet Models 17 Jan 27, 2010 10:04 PM
Yippee! jet design contest 2nd entry-Dassault Mirage 2000b Bryce From Nice Electric Ducted Fan Jet Talk 16 Nov 24, 2005 12:10 PM
Rave mirage for jet design contest chris3dd Electric Ducted Fan Jet Talk 4 Jan 30, 2005 09:21 AM
Jet design contest entry #2- SR-71 pusher kennypinkerton Electric Ducted Fan Jet Talk 2 Aug 22, 2004 12:42 PM
