Aug 29, 2016, 10:02 AM
New Product
FMS 2000 mm Beaver
FMs has announced the release of the 2000 mm Beaver.
First shipment is due late October to Mid November.
Here are the Specs and First Flight photos. You will notice in the last few photos a multi color streamer. This is showing the tow hook and release.
Floats will be an option and I have asked about Skis for our Northern customers. FMS is looking into.
Jim
Wingspan: 2000mm/78.7in
Overall Length: 1,304mm/51.3in
Flying Weight: Around 3,800g
Motor Size: Brushless 4258-KV550
ESC: 70A
Servo: 6 x 17g metal digital
Radio: 6 Channel
CG (center of gravity): 70-75mm (From Leading Edge)
Prop Size: 15*9
Recommended Battery: Li-Po 22.2V 4000mAh
Aileron: Yes
Elevator: Yes
Rudder: Yes
Flaps: Yes
Retracts: No
Approx. Flying Duration: 15 minutes
Minimum Age Recommendation: 14+
Experience Level: Intermediate
Assembly Time: 10 minutes
Wing Load: 71.1g/d㎡
Wing Area: 53.4d㎡
Aug 31, 2016, 10:37 PM
That color scheme is absolutely butt ugly!!
Old Dawg
Sep 01, 2016, 04:39 AM
Lynxman's Avatar
The shape looks ok. Looks kind of chubby though, with a long nose and big wheels.
Sep 01, 2016, 09:42 AM
Doug Bartley's Avatar
Disgusting representation of a classic aircraft!! I wouldn't take one for a $1!!
The designer obviously never spent more than 2 minutes with a 3 view, so much wrong!Doug B
Sep 01, 2016, 10:50 AM
What you are seeing is the first CNC prototype. Refinements are in progress
Sep 01, 2016, 06:42 PM
It appears the nose was extended to allow a battery hatch. On a real scale Beaver, the hatch would be in between the wing mounts typically or thru the bottom to get batteries far enough forward. The over sized wheel look rediculous too! Either go smaller or install Tundra style, small hubbed wheels. Typical cheap engineering and shortcuts. The classic Beaver deserves better! fwiw Doug B
Sep 02, 2016, 03:43 AM
Micro-Turbine Superhero
henke's Avatar
this is not giant scale, and it's a foamy!
Sep 16, 2016, 10:26 AM
panamarenko's Avatar
What do you mean with refinements?
I see a lot of scale failures, like other people did here, it's a pity.
ST Model DHC-2 beaver should be a reference for other brands.
Most hugly stuffs in this model:
- nose lenght,
- motor cowl and motor cover (no plastic cylinders?),
- color scheme, not even like the real one,
- window frames, should be at least with black plastic sheet or transparent,
- floats are not scale enough, no details.
+ stuffs:
- FMS product,
- size, 200 mm wingspan,
- price?,
- flight performances?,
If you have contatcs with them, try to keep their attention on our remarques.
Like that it will remain only a foamy plane made in Shenzen, like a thousand other examples.
But not a winner at all.
Thank you for posting these pics!
Sep 19, 2016, 09:29 AM
Beaver on Optional Floats.
Photos from FMS factory.
Jim
Sep 19, 2016, 09:44 AM
Thank you!
Sep 19, 2016, 09:46 AM
Did you have some exchange of opinions meanwhile?, I don't see any refinements or improvement on the model....
This black livery, is a killer for foam, in summertime.
Floats struts are not scale at all.....
Sep 19, 2016, 06:27 PM
you need to start all over, thats one ugly beaver, take a look at the flyzone beaver, and copy that, then you will have a beaver. and dont paint it, let use do that, offer decal kits
Sep 19, 2016, 06:41 PM
Jim
This is what a beaver looks like copy this, make it so the side door opens , take a look at the floats 2 rudders, that thing you got looks like a cheap toy , cnc what did you cnc it from some child's toy fisher price
Sep 20, 2016, 10:07 AM
The factory has refined the paint and foam and has been tested to not be an issue in the summer sun.
As for scale like, this is my two cents.
Back in the day we had to build from a box of sticks and it it came out looking like a plane be it Beaver, P-51, F4u etc... you took it out and flew it and were very proud of your accomplishment. So today while it is not perfect as you want it, it is designed to make your flying time enjoyable.
Jim
Sep 20, 2016, 12:02 PM
Jim
so you dont like feed back
