Aug 24, 2016, 08:15 PM
kiwi_craig's Avatar
New Product
WL -V950 CP heli - 200 size
new WL -V950 CP heli - 200 size
https://www.banggood.com/WLtoys-V950...474558201403EJ
sure looks like a Master CP clone to me.................
3G / 6G system like the smaller WLs / XK's, hopefully flies as good !
Aug 25, 2016, 03:17 AM
kiwi_craig's Avatar
WLtoys V950 2.4G 6CH 3D6G System Brushless Flybarless RC Helicopter RTF
WLtoys V950 Brushless Flybarless RC Helicopter Features
3D mode and 6G mode integrated,can be switched freely.
Including exclusive adapter and balance charger.
Blades design by using aerodynamics to provide power with flybarless system.
Normal (aka 6G) activates 6-axis gyro, allows stable flight, suitable for beginners
Violet fly through 1912 2830KV brushless main motor,equiped with 3s 1500mAh 25c Lipo battery for better and long fly time.
D Mode activates 3-axis gyro, enables aerobatics such as flips, rolls inverted flight, funnels and tick-tocks
6CH Transmitter has 3D aka Idle-Up switch, Throttle Hold switch, large LCD, low voltage warning.
Hovering midpoint setting allows setting of the hovering point.
WLtoys V950 Brushless Flybarless RC Helicopter Specs
Body Length: 450 mm
Rotor Diameter: 460 mm
Height: 170mm
Control distance: About 120 m
Remote mode: 2.4G remote control
Battery: 11.1V 1500mAh 25C
Flight time: About 15 minutes
Tail Motor: Iron core 050
Main Motor: Brushless(1912) 2830 KV
Size of Original Package: 54* 26.6 *14.8 cm
Weight: 402g
Aug 25, 2016, 03:22 AM
kiwi_craig's Avatar
DutchRC - WLtoys V950 Entry level 3D Helicopter.. Any good?? - Show & Tell (from Banggood.com) (18 min 34 sec)
V950 test (8 min 1 sec)
Aug 26, 2016, 05:02 AM
What goes up...............
Flyingboats's Avatar
Yep pretty hard to go past that "violet fly"
Looking forward to see how this one turns out. Have been very impressed by the handling of the V930 and V977 so if they can replicate that it will be a good bird...
Aug 29, 2016, 09:47 AM
I hope XK release this instead.
Aug 29, 2016, 04:55 PM
This looks interesting. Does anyone know if the gyro will be adjustable?
Aug 29, 2016, 07:49 PM
Not much info. I see the Banggoods presale price now showing as $129.95, arriving September 16th. Not too long......
Aug 29, 2016, 10:46 PM
kiwi_craig's Avatar
at the big 10 year sale around then also ! getting tempting !
Aug 29, 2016, 11:10 PM
kiwi_craig's Avatar
NEW PICS UP
http://www.banggood.com/WLtoys-V950-...34de7011f89f01
PCB: looks like a cross between the FX and V977 board layouts, and sure looks like a KN chip on there.....
pity about the puke colour scheme............
hope the tail gears are robust..........
Aug 30, 2016, 01:54 AM
battery seems a bit large for a 200 size heli, though it must be pretty light being mostly plastic. id still probably put a smaller battery in it,
also no BNF option? have they changed the protocol agian... looks like same tx as other wl toys helis.
Aug 30, 2016, 05:30 AM
kiwi_craig's Avatar
1300 - 1500 is a very popular mode on the walkera master CP, which this is a clone / upgrade of.
protocol, looks like a KN chip on the board layout............ soon see..............
Aug 30, 2016, 07:19 AM
If its KN protocol id be very interested as an intermediate between my copterx 250 and v977.
BNF id be hoping to be about 70 which is pretty good and if it flies decent.
Aug 30, 2016, 11:38 AM
3D Ambitions's Avatar
They should have made it a torque tube driven tail instead of that cheesy looking motor driven gear setup.
Aug 30, 2016, 05:07 PM
Zaphod69's Avatar
New photos show its a Master CP clone down to the frame. Biggest difference is the brush less main motor.
Sent from my Nexus 9 using Tapatalk
