New Product
WLtoys V950 450mm 2.4G 6CH 3D6G System Brushless RTF - $149.99
more details: http://www.banggood.com/WLtoys-V950-2_4G-6CH-3D6G-System-Brushless-Flybarless-RC-Helicopter-RTF-p-1080417.html
description has some inconsistencies Description: Rotor Diameter: 460 mm Body Length: 450 mm Height: 170mm Weight: 402g Battery: 11.1V 1500mAh 25C Flight time: About 15 minutes Control distance: About 120 m Main Motor: Brushless(1912) 2830 KV Tail Motor: Iron core 050 Remote mode: 2.4G remote control Size of Original Package: 54* 26.6 *14.8 cm Features: 1. Blades design by using aerodynamics to provide power with flybarless system. 2. Violet fly through 1912 2830KV brushless main motor,equiped with 3s 1500mAh 25c Lipo battery for better and long fly time. 3. 3D mode and 6G mode integrated,can be switched freely. 4. 6CH Transmitter has 3D aka Idle-Up switch, Throttle Hold switch, large LCD, low voltage warning. Hovering midpoint setting allows setting of the hovering point. 5. 3D Mode activates 3-axis gyro, enables aerobatics such as flips, rolls inverted flight, funnels and tick-tocks 6. Normal (aka 6G) activates 6-axis gyro, allows stable flight, suitable for beginners 7. Including exclusive adapter and balance charger. 8. Flying weight: 58.5g; Flight time: 15 mins. Package Included: 1 x WLtoys V950 6CH Brushless Flybarless RC Helicopter 1 x Transmitter 1 x Charger and adapter 1 x 11.1V 1500mAh 25C Battery 1 x Accessories bag (gear + blade) 1 x Manual |
Not 450 size its 250 size
sorry thats not a 450 size helo but a 250 size helo, my FC070c is barely a 400 size helo and it has a blade size of 610mm.
This V950 is nothing more than a updated clone of the walkera 250 size Master CP, the V950 even uses the exact tail holder mount and motor design. the updates are the brushless motor, bigger battery and better 6 axis gyro, still worth a look at it when it comes out though, I bet my Master CP blades will fit right on that head, would not surprise me if WLToys cloned the Master CP head design also. |
This is great, clone of master cp or not the master cp is too good to die. I learned on it, its a great heli.
I have ordered one.
I have the walkera master cp and had previously a v977. If the v950 benefits from both, it will be a MUST. The master cp flies well, very stable, reasonably crash proof, maintenance is very easy. The servo upgrade to metal gear is mandatory. But the master cp is brushed = not much powerfull, the motor is hot and the lipo suffers. The v977 is very stable especially in 6G and very crashproof like all class 100 heli. The radio is not programmable. I use a devo 8S with deviationtx and the additional tx module mod that will allow me to fly the v950 and its KN protocol. I have already fly different helis with various protocols with this radio. Most of the v950 spare parts will be compliant with marster cp. Wltoys prices should be lower. The brushless ESC should be easily upgradable with a better ESC with governor mode.... but I don't know yet how the tail motor is powered using a separate brushed ESC or not... A mod exists for the master cp to upgrade the tail to brushless : same mod will apply to v950. For me this v950 is very promising... lets wait now. |
Reason: no mod is required on the v950 side to use a devo TX
$60 Copter X 250 FBL $28 Henge 922/933 servos $10 Yep 30A $20 Gartt Motor $30 budget friendly FBL $5 Lemon DSM2 $153 - total If you've got in your head that the 950 is what you need, don't let me sway you. But for others, this is something to consider before you push the buy button. |
I thought you misread my message.
For V950 I would still like to get rid of the stock KN RX assuming I like all the rest. I won't use the stock TX. That would be $150 + say, $30 budget friendly FBL + $5 Lemon DSM2 (+ $?? to support/convert the brushed motor tail) for me to own a V950 RTF. If there is a XK BNF equivalent with sFHSS based RX, it would be nice. |
yes your argument with the copterx makes sense also.
The building and the fine tuning of a 250 copter x has nothing in common with a RTF bird. If your pleasure is the assembly : it is different of course. For me I will not use the stock tx but my devo 8S. No mod is needed on v950 side. I can use it out of the box. Sooner or later I will want to sale the v950 and the bundle with a TX makes it much more easy to sale to a beginner at an acceptable price. I also have a 450 clone, smaller heli are more training tools. I don't fear to crash and don't fear the blades in case of accident on me. I'm not sure that i would not fear a 250 clone with lots of metal parts. I confirm that the marster cp is reasonably crash proof if you crash on grass. |
Received my v950 today but its missing a servo link so much for quality control. Now got to chase up Banggood and weeks of waiting for parts. Very dissapointed.
WLtoys V950
here is only $127
https://www.aliexpress.com/item/WLto...5-b2e015b374d5 for parts is here http://www.wl-toys.com/Wltoys-V950-R...221-1321-1.htm |
