Aug 23, 2016, 01:14 AM
New Product
$10 FrSky XM 1g 16CH SBUS Micro Rx & $16 FrSky XM+ 1.6g Full Range 16CH SBUS Micro Rx
FrSky has released what appears to be the smallest FrSky compatible Rx, the 1g FrSky XM, and a slightly larger "full range" (supposedly the same as the FrSky X4R's) FrSky XM+
FrSky XM 1g 16CH SBUS Micro Rx details: http://www.banggood.com/FrSky-XM-2_4G-16CH-Telemetry-Receiver-p-1107435.html
FrSky XM+ Full Range 1.6g 16CH SBUS Micro Rx details: http://www.banggood.com/Frsky-XM-Micro-D16-SBUS-Full-Range-Receiver-Up-to-16CH-p-1110020.html
FrSky XM specifications:
Specification:
Brand name: Frsky
Item name: XM receiver
Number of Channels:Up to 16CH from SBUS(CH1~CH15 for PWM, CH16 RSSI for FC
Operating Voltage Range:3.5~10V
Operating Current:[email protected]
Operating Range:>600m
With RSSI output on board:Analog 0~3.3V
Firmware Upgradeable
Compatibility:FrSky D16 mode
Dimension:15x10x3.5mm(LxWxH)
Weight:1g
Package Included:
1 X Receiver
FrSky XM+ Specifications:
Specification
Dimension: 21.5*12*3.5mm(L x W x H)
Weight: 1.6g
Number of Channels: Up to 16CH from SBUS (1-15ch for PWM,16ch RSSI for FC)
Operating Voltage Range: 3.7~10V
Operating Current: 30mA @5V
Operating Range: 1km
With RSSI output on board: Analog 0~3.3V
Compatibility: FrSky D16 mode
Package Included:
1 X Receiver
Tiny FrSky 8CH SBUS Micro Rx: http://www.banggood.com/Tiny-Frsky-8CH-Receiver-Compatible-With-FRSKY-X9D-Plus-DJT-DFT-DHT-For-QX90-DIY-Micro-Quadcopter-p-1079963.html
[B]
Tiny FrSky 8CH SBUS Rx specifications:
Description:
Item Name: Tiny Frsky 8CH Receiver
Work mode 8 Mode
Output: PPM/SBUS
Number of channels: 8
Range: Approx 800m
Weight: 3g
Dimensions: 12 x 25mm
Optional: With pin and line, Without pin and line
Feastures:
Compatible with FRSKY ACCST
Compatible with X9D(Plus)DJT/DFT/DHT
Small and light weight
Can be update the firmware for two-way transmission, two-way transmission suit for indoor FPV, With the use of Cleanflight have RSSI feedback signal.
Suit for Eachine Tiny QX90, QX80 Micro Racing Quadcopter.
Package Included:
1 x Tiny Frsky 8CH Receiver
1 x Signal line
Aug 23, 2016, 09:17 AM
Originally Posted by lmpuIse
more details:
Does anybody understand what exactly they mean. You can get an firmware update to enable telemetry from the flight controller? If so, where can you download the firmware? En how does one wire the receiver up?
Aug 23, 2016, 09:33 AM
humayraykinaon's Avatar
Doesn't have fail safe?
Sep 05, 2016, 10:00 PM
Anyone tried this thing yet?
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Sep 05, 2016, 10:26 PM
It's best asking it here......
https://www.rcgroups.com/forums/show....php?t=2705040
Oct 04, 2016, 04:20 AM
Yes I have tried it, it works great with SBUS. can also do PPM. But not sure about the range, I will use a taranis to see the RSSI signals.
Oct 11, 2016, 05:26 PM
Team ATees
theledman's Avatar
Weird, I've bought two and configured both for SBUS. Neither work. I've confirmed that they both bind to my taranis (D8. light remains steady and flashes when i turn off my radio) but for whatever reason, my FC doesn't recognize them (X4R works fine though so the FC isn't the issue).
I'm at my whit's end with these guys so if anyone has thoughts on what i might be doing wrong, let me know.
Oct 11, 2016, 05:58 PM
We are not men, we are DEVO 7e
xanuser's Avatar
more details:
link looks like this,
Code:
Code:
but is really this,[URL="http://goo.gl/71gbjy"]
why not be up front about your links, instead of trying to hide them?!
Latest blog entry: MY notes/ Ascent 2"build notes
Oct 13, 2016, 01:35 PM
Team ATees
theledman's Avatar
Nevermind. Figured it out: I found the inverter on this board.
If you're running a F1 FC without a built in inverter, solder your signal wire directly to this pin:
Oct 13, 2016, 02:58 PM
PcolaQuad's Avatar
Check out this thing!!! I bought two from a fellow RCgroups member and love it. Nice signal, easy to set up and does not require an inverter. For Naze32 rev 5 just hook it straight up...
http://furiousfpv.com/product_info.p...63c6f43f5823a3
Oct 21, 2016, 05:44 PM
Crady's Avatar
And it's nearly double the price
Oct 21, 2016, 05:45 PM
Crady's Avatar
Anyone know how to get telemetry working on the A1 and A2 inputs?
Also, is the DIP switch for setting PPM and SBUS? I connected to a SP Racing F3 via SBUS and regardless of the switch positions I was still getting signal
Oct 24, 2016, 03:56 AM
More, Anyone know how to get telemetry ? How to flash it ? Tried with avrdude but got 'not responding' message
Oct 24, 2016, 11:04 AM
Crady's Avatar
Did you locate a source for the firmware update? I found this diagram on the Banggood website (I believe you'll need an FTDI board to flash it.)
While Banggood says you can get RSSI via a firmware update, they make no mention of telemetry through the A1 or A2 pins. What's really infuriating is they tell you that you can upgrade it but then fail to provide a link to the required firmware.
Beyond that, the two boards I received work fine in both SBUS and PPM modes when tested with an SP Racing F3 Deluxe and a NAZE32 r5, respectively.
Oct 25, 2016, 01:45 AM
Hi, If anyone can help on below, it would be great!
https://www.rcgroups.com/forums/show...8#post36038321
Thank you
