Aug 30, 2016, 12:50 AM
Slope Trash
McLoop's Avatar
I was flying with Frank that day. He's not exaggerating! That thing is smokin fast and full of floaty goodness. Out flies everything.
I want one.
Aug 30, 2016, 01:43 AM
flyin' fool
goldguy's Avatar
See! Told ya.
Aug 30, 2016, 02:12 AM
flyin' fool
goldguy's Avatar
rcflydad: (others are welcome too)
First off, building light is the answer, 'light is might'. Check out the SST videos. My inspiration to make a light Boomer that would 'rock n' roll' when only Whipits can be flown.
Your answers...........
*Servos............... https://www.hobbyking.com/hobbyking/s...0sec_5_6g.html
*Lam film is 1.7, I think.
* 1.9# EPP
* Single PW51 outie template
*Elevons/vert stab are tapped 2mm Depron
*.4 Styrene for cover (not ABS) from a HS that sells train stuff.
* hinge tape is Duck brand HD crystal clear.
* Have a DX6 and an Orange T6, so use both the R410 DSMX and the R610V2 DSM2 RXs.
* The flat battery is a Team Losi from HS a few years ago.
Use whatever you have and increase the wing area if necessary to keep the loading down to - 3.0 oz. per sq. ft.
Hope this helps............... Fly Small, Have a Ball
Aug 30, 2016, 02:31 AM
flyin' fool
goldguy's Avatar
A tuning session at the maiden yesterday of my latest at our 'every Monday of the year' float flying............... the OddBall, flew great.
The NutBall even makes a good sloper if you need to turn out a flying machine in 1/2 hour cause all your birds are smashed.
Sep 01, 2016, 02:51 PM
Post 11 updated
Hi Frank,
I updated my Post 11 with your responses. Feel free to add any more details in future posts.
rcflydad
Sep 02, 2016, 02:44 AM
flyin' fool
goldguy's Avatar
The short answers..............
arborite scraps
cut off at 2/3mm thick
just back from the CG and done with an s/iron and washer with large inside dia. hole
in storage, google pivot cutters
.065/ cut 'V'/CA
2mm depron X 1"
fin is B 5, H 3.25, S 3.5, back 7" from LE (done TLAR)
lam film bought locally/ try 'Alofthobbies / new stuff
hot glue
forward of CG with hot glue
K&S #502, whatever size that is / Hobby King items
Hobby King, usually on BO, google LemonRX
Batt/RX comp just behind LE/ solder iron/ tape
craft store
Sep 25, 2016, 03:50 AM
flyin' fool
goldguy's Avatar
Here's a 28" span Boomer Lite with a KF airfoil at 2.4 ounces. Flies amazingly well in light lift/wind.
Sep 25, 2016, 03:52 AM
flyin' fool
goldguy's Avatar
My buddy spent $0.75 on building materials to turn it out.
Sep 25, 2016, 01:02 PM
Reap the wild wind
headlessagain's Avatar
Wow, that's one expensive plane Makes my NCFM Wabbit seem like such a bargain
KFm-2 or 4?
Andy
Sep 25, 2016, 09:41 PM
flyin' fool
goldguy's Avatar
Two
Sep 26, 2016, 03:43 AM
Reap the wild wind
Thanks Frank
Nov 03, 2016, 06:57 PM
flyin' fool
goldguy's Avatar
Add 2.5 ounces of lead to a 4.5 ounce Boomer in 40 kph winds and what do you get? An amazing afternoon of ballistic flying.
Jan 01, 2017, 06:35 AM
Professional amature
Hey Frank,
I thought I would post a drawing I made of your fantastic servo plug power/charge invention.
Ed
Jan 01, 2017, 12:47 PM
Reap the wild wind
A quick but probably dumb question
Is there a way of using a Y lead in the above arrangement as I tend to use RX packs which already have the + and - servo plugs to the rx in place?
Andy
Jan 02, 2017, 03:09 AM
flyin' fool
goldguy's Avatar
Negative.
