T-REX 470LM Dominator Super Combo
The new T-Rex 470LM is the latest release from one of the most popular companies in the RC helicopter market.
Align has an all new combo ready to hit the market.
The new T-Rex 470LM is the latest release from one of the most popular companies in the RC helicopter market. Some of the new features on the 470LM are the newly designed belt drive system (a release of a torque tube version is on the way), new rotor head design that loses the DFC system. The new landing gear gives the helicopter a 5 degree forward tilt and the servos are the new HV DS450M/HV DS455M High voltage versions. The ESC is the new RCE-BL50X to handle the 6 cell power system and the main shaft has an added 3rd bearing in the main block. All of which makes the 470LM Dominator Super combo an excellent choice for taking the guesswork out of choosing the electronics for your 3D power house.
The new T-REX 470LM Dominator Super Combo main features:
  • Brand New Belt Drive Assembly
  • Brand New 470EFL Main Rotor Head Set
  • 380 Main Blade/69 Tail Blade
  • Progressive Landing Skid with 5 degree forward tilt
  • DS450M/DS455M High Voltage Digital Servo
  • RCE-BL50X Brushless ESC
  • The 3rd Main Shaft Bearing Block
  • Brand New Tail Rotor Holder
For more information on the new 470LM click here.
Aug 17, 2016, 04:31 PM
I wonder if the new Main Rotor head design will find it's way into the larger heli's, like the 550L.
Aug 18, 2016, 06:05 AM
Nice!!
Sep 22, 2016, 04:16 PM
Turnigynarian
2Doggs's Avatar
Looks like a great update, with a decent powertrain and beefier shafts to match the competition. No mention of increased tailshaft diameter, tho. Ff they stayed with 3mm they really dropped the ball.
Sep 22, 2016, 10:15 PM
I'm going to end up waiting this one out now. The 500L kits are going for just under $375 with discounts so I grabbed one of those instead. I'll probably regret it later.
Sep 23, 2016, 02:25 PM
fpainter3's Avatar
They stole BEAM's tail drive and added a tensioning spring.
I wanted a Synergy E5, but did not want a shaft driven tail.
I ended up rebuilding a Synergy E6. It has the same belt configuration.
After testing and selling many crappy systems They got rid of the DFC head and the torque tube. Good to see they learned their lessons.
Sep 23, 2016, 02:46 PM
Turnigynarian
2Doggs's Avatar
The direct drive tail has been around a long time, I don't think Beam were the first to come up with it. Good to see it coming back, however.
Sep 23, 2016, 02:52 PM
BEAM? I thought they stole it from Blade?!?!?!
I guess I'm in the minority, I love the simplicity of a DFC head, especially Tarot's split lock.
Sep 23, 2016, 05:01 PM
fpainter3's Avatar
Here is what I think about the DFC head
https://www.rcgroups.com/forums/show....php?t=2727901
We don't need to pollute this thread, because I am liking this new helicopter, maybe as much as a delux Gaui X3
The tail control is looking good, I wonder if it can go over center and lock up like the older ones?
I hated the 450 PRO, IMO the SE was a better machine once you added a few mods
Oct 10, 2016, 05:07 PM
The problem with all new align helicopters is that they are heavy.
The 500l is 1 heavy helicopter.
Oct 12, 2016, 08:00 PM
what is the deference between Align T-REX 470LM RH47E01XW and RH47E01XT I bought the
RH47E01XW
Oct 12, 2016, 11:02 PM
You are not minority, I really dont understand why some complain about dfc heads, I have had so many flights with them and never had issues and really cant see why anyone would, they work perfectly fine.
Dec 03, 2016, 08:59 PM
Tail Lock up w Long Shaft
The tail control is looking good, I wonder if it can go over center and lock up like the older ones?s
T-Rex 470LP Kit box has a red sticker w tex Lengthen Shaft
Longer shaft will lock up so you need to add a washer or washers to prevent lock up. You could limit the travel by the FBL controler but wind gust or hard 3D may over ride a limit.
Dec 03, 2016, 09:15 PM
Align 470L Turnbuckles
Kit Review
470Lp is a better kit than any of my other Align or Clone kits.
Screws are better
Frame is sanded
Blades
CG and Weight off and were correct
Bearings
Head bearing configuration was changed to 450L configuration + remove spacer installed brass metric washers.
Ball extension for A P & E servo arm is a big improvement
3 bearing design is super
Main Shaft is now 6mm
LiPo
Opening is 40.5x53.5x300mm
Lipo tray is improved
Landing skid Raked is so good I added Aligns 470L skid to all my 450s
ESC
50A w 70A peak ESC and 6A servo & FBL controller power
Extra Parts
Align T-REX 470L Counter Thread Main Linkage Rod Set # H47H004AX $5.99
Dec 06, 2016, 07:33 PM
Which shall it be, Passworthy?
Brown Elf left mine on the front porch today. :-)
Packaging looks nice. Hope the bird is. Probably won't get it assembled 'til a while after I get the new lens in the other eye (cataracts).
Dave
