Aug 12, 2016, 08:38 AM
Mini-Review
GPTOYS S911 RC CAR FOXX, 32 + MPH. CAR TRUCK. SCALE 1-12. A car for all terrains even
GPTOYS S911 RC CAR FOXX, 32 + MPH. CAR TRUCK. SCALE 1-12. A car for all terrains even with water. LTECNIC
An impressive drive car with the two rear wheels with incredible force. This car is cast to resist everything including water, strength and endurance are the hallmarks of this car that gets speeds up to 40 km / h, great for all the land we can start in this world of rc with a car an incredible price with great performance.
We have two red and blue colors with a very attractive design and incredible wheels for any surface and can make spinning tops with impressive.
Link gptoys: http://goo.gl/2ZrjBZ
Link gearbest rc deals: http://goo.gl/AnxNuE
Link battery: http://goo.gl/qp7IMD
With the charging voltage protection, low power protection, overheating protection
independent four-wheel suspension and transmission metal.
The support of more than 8 cars to compete in the same field
S911 has almost all the features you need in a car off the road
quality certificates and qualifications 3C: ROHS, R & TTE, EN71, EN62115, EN60825, HR4040, ASTM, 6P
Control distance: about 80 meters
Speed: 42 kmh
Charging time: 2 hours
Playing teeth: 10 minutes
Car battery: 800MA-Li-ion Fe
Car size: 32 x 26.5 x 15 cm
Budget
general
Brand: GPTOYS
Type: RC Trucks
Material: Electronic components, plastic
Primary information.
Remote Control 2.4 GHz Wireless Radio Control
Transmitter Power: 2 x 1.5V AA batteries
Battery: 9.6V 800 mah, Built-in rechargeable battery with a running time of about 12 to 15 minutes.
Dimension and Weight
Package Weight: 1,911 kg
Package size (L x W x H): 37.50 x 28.00 x 18.00 cm / 14.76 x 11.02 x 7.09 inches
package contents
Package Contents: 1 x RC trucks, 1 x remote control, 1 x Li-ion battery 800MA-Fe 1 x Charger, 1 x Screwdriver
Subscribe: http://goo.gl/bDy5xh
Facebook: https://www.facebook.com/ltecnic/
CAR RC GPTOYS S911 FOXX,32 + MPH CAR TRUCK ESCALA 1 12 Un coche para todos los terrenos incluso c (6 min 53 sec)
Aug 12, 2016, 04:29 PM
Fan of just about anything RC
SoloProFan's Avatar
Has the slipping pinion issue been fixed now?
Latest blog entry: For the love of the hobby!
Aug 12, 2016, 06:39 PM
G toys s911
I took several days to walk and it's going great tele charged battery as about 20 times and I have no maybe yes culé a little problem but the traction of both rear wheels only but otherwise all good, no problems with the motor and gears
and I'll tell you when it takes more hours filmed
Aug 13, 2016, 02:09 AM
SoloProFan's Avatar
Ok, maybe it's fixed. I got an early one, and the motor pinion is just press fit on the axle. Also, it's aluminium. So the motor heats up as you drive, the pinion expands as it gets hotter, and starts to slide on the steel axle of the motor, eventually stopping the car. You can hear the motor running, but the wheels don't turn. Letting it cool down a few minutes, the pinion cools down, shrinks, and becomes a tight fit on the motor again, so you can drive, until it happens again.
Aug 13, 2016, 06:18 AM
911
same thing happened to me that 9116 you had to adjust the pinion and a couple of times with this 9111 but still have not had that problem happen I hope not anyway you what happens if I comment
Aug 13, 2016, 08:56 AM
SoloProFan's Avatar
Maybe they fitted a different pinion, or added some grooves on the motor axle. Or drilled a smaller hole in the pinion, so it's a tighter fit on the motor axle.
Discussion GPTOYS S911 RC CAR FOXX, 32 + MPH. CAR TRUCK. SCALE 1-12. A car for all terrains even LTECNIC Off-road Cars 0 Aug 12, 2016 08:32 AM
