May 26, 2019, 05:05 PM
Just Plane Nutts
AirDOGGe's Avatar
The Teflon tube is required.
If you ran in salt and did not fresh-water flush afterwards, then those items may be fused to the shaft via corrosion and have to be forced off.
Photos?
Jul 15, 2019, 03:31 PM
replacing ESC/receiver
I toasted the esc/receiver. Is the stock replacement the best option?
I could get a hobbyking water cooled esc and separate waterproof receiver for about the same price.
Do I really need a water cooled esc? I have 30a esc's, do they really get too hot with this size motor?? Would 40a compensate for heat?
Sep 04, 2019, 06:21 PM
hello! fastmax what mods for change of motor and what motor you have in wl915
Sep 07, 2019, 08:31 AM
I want one motor outrunner of 3200 kv . Which one would be ok for this boat? and which battery do you recommend for it?
Sep 09, 2019, 10:53 PM
Just Plane Nutts
AirDOGGe's Avatar
Try here: https://www.ebay.com/itm/One-Dime-RC...AAAOSwBkNcDSR6
This one has built-in water cooling: https://hobbyking.com/en_us/ads-400x...00kv-525w.html
Battery choice is subjective depending on who you ask. Just don't buy the cheapest ones you can find and you'll be alright. Cheap Li-Po's always disappoint.
I recommend 1500mAh 3S packs, 30A or higher to keep weight down and performance up ... 2200mAh 3S maximum for this hull to control weight gain.
Sep 10, 2019, 03:24 PM
Thank you for the info. Must I change the mount to use these motors?
Sep 14, 2019, 12:49 AM
Just Plane Nutts
AirDOGGe's Avatar
Standard bolt spacing center-to-center for 28mm diameter brushless motors is 19mm, usually M3 threads. Some offer 19mm and 16mm bolt spacing holes, with 19mm most common. I know of one that only has 16mm spaced holes Measure your mount's hole spacing to verify.
Sep 15, 2019, 03:36 PM
those engines are very long and does not fit with the esc
Sep 16, 2019, 02:50 PM
Just Plane Nutts
AirDOGGe's Avatar
Move it if needed.. This is modification, not bolt-in upgrades.
Sep 19, 2019, 12:23 PM
Ok thanks!
Oct 12, 2019, 01:53 PM
Boaters are nice people.
Be aware of the fact the ADS motors come with a 3 mm shaft, so a new coupler is in order.
Otherwise, the ADS motors work fine, as does their watercooling, I get over 20 minutes full throttle on a 2S 4200mAh lipo...
Regards, Jan.
Oct 13, 2019, 10:53 AM
in what boat?
Oct 13, 2019, 07:36 PM
Just Plane Nutts
AirDOGGe's Avatar
Using in salt water and did not clean/rinse one time and let sit for weeks.
I won't even put mine away after fresh water runs until after servicing it. Lesson learned, and more boat components may fail early too. Good luck with that.
At least they are CHEAP boats.
