Serial output from FS-IA6 (Semi I-BUS) - RC Groups
Jul 30, 2016, 12:56 PM
Hello there fellow RC people.
i would just like to document a finding a made.
I searched high and low for a Serial/IBUS output from a FS-IA6 receiver without success.
But i did find this post by Alex that were intresting.
https://www.insidegadgets.com/2015/1...r-fpv-display/
i tried to get more information about the clock and data pin without success. i doubt its plain SPI communication.
but when i got fed up with those pins i tried to poke about and try to find a IBUS protocol, like what it is on the IA6B receiver.
One pin poked my intrest. i applied a UART filter on it and got some data.
(Pin 11, check attached image.)
The whole packet size is 31 bytes long.
1 Starting byte
14 channels @ 2 bytes each (28)
2 checksum bytes.
every 3.85ms
at 115200 baud rate.
*** Difference from IBUS Protocol. ***
The IBUS protocol has two starting bytes and calculates the checksum differently.
Sample packet:
Code:
55 DD 05 DC 05 EB 03 DC 05 E8 03 D0 07 D2 05 D9 05 E8 03 E8 03 DC 05 DC 05 DC 05 DC 05 23 4C
0x55 is the starting byte.
then we have the data for each channel.
Code:
1501,  1500,  1003,  1500,  1000,  2000,  1490,  1497,  1000,  1000,  1500,  1500,  1500,  1500
And then the checksum, in this case its
Code:
23 4C
Get them by doing:
Code:
  rcValue[ 0] = (data[ 2] << 8) + data[ 1];
  rcValue[ 1] = (data[ 4] << 8) + data[ 3];
  rcValue[ 2] = (data[ 6] << 8) + data[ 5];
  rcValue[ 3] = (data[ 8] << 8) + data[ 7];
  rcValue[ 4] = (data[10] << 8) + data[ 9];
  rcValue[ 5] = (data[12] << 8) + data[11];
  rcValue[ 6] = (data[14] << 8) + data[13];
  rcValue[ 7] = (data[16] << 8) + data[15];
  rcValue[ 8] = (data[18] << 8) + data[17];
  rcValue[ 9] = (data[20] << 8) + data[19];
  rcValue[10] = (data[22] << 8) + data[21];
  rcValue[11] = (data[24] << 8) + data[23];
  rcValue[12] = (data[26] << 8) + data[25];
  rcValue[13] = (data[28] << 8) + data[27];
Then to calculate the Checksum:
Code:
int checksum = (data[30] << 8) + data[29];
int myChecksum = 0;
for( int c=0; c<14; c++)
  myChecksum += rcValue[c];
if( myChecksum == checksum )
  Serial.println("Checksum valid!");
And i got the FS-i6 transmitter with the modified 10ch firmware.
and it transmits all the 10 channels
Hope someone might find this useful and i apologise if it has been documented before.
I dont think you can input this directly into popular flightcontrollers right now. someone needs to write a snippet to wait for the starting byte and calculate the checksum .
But i believe it will be very easy for a Atmega based MultiWii controller.
Jul 31, 2016, 09:02 AM
Hi,
thank you very much. With your help I successfully transfered this to betaflight.
It works with the PIN visible in your image. I use the stock FS-IA6 but should work
also with the modded 10ch firmware.
I will soon set this as a PR to betaflight. If you want I can upload hex files for your TARGET (FC Board) for testing.
diff --git a/src/main/rx/ibus.c b/src/main/rx/ibus.c
index 507df1e..5d12b87 100755
--- a/src/main/rx/ibus.c
+++ b/src/main/rx/ibus.c
@@ -42,9 +42,9 @@
#include "rx/rx.h"
#include "rx/ibus.h"
-#define IBUS_MAX_CHANNEL 10
-#define IBUS_BUFFSIZE 32
-#define IBUS_SYNCBYTE 0x20
+#define IBUS_MAX_CHANNEL 14
+#define IBUS_BUFFSIZE 31
+#define IBUS_SYNCBYTE 0x55
#define IBUS_BAUDRATE 115200
@@ -125,14 +125,14 @@ uint8_t ibusFrameStatus(void)
ibusFrameDone = false;
- chksum = 0xFFFF;
- for (i = 0; i < 30; i++)
- chksum -= ibus[i];
+ chksum = 0x0000;
+ for (i = 0, offset = 1; i < IBUS_MAX_CHANNEL; i++, offset += 2)
+ chksum += ibus[offset] + (ibus[offset + 1] << 8);
- rxsum = ibus[30] + (ibus[31] << 8);
+ rxsum = ibus[IBUS_BUFFSIZE - 2] + (ibus[IBUS_BUFFSIZE - 1] << 8);
if (chksum == rxsum) {
- for (i = 0, offset = 2; i < IBUS_MAX_CHANNEL; i++, offset += 2) {
+ for (i = 0, offset = 1; i < IBUS_MAX_CHANNEL; i++, offset += 2) {
ibusChannelData[i] = ibus[offset] + (ibus[offset + 1] << 8);
frameStatus = SERIAL_RX_FRAME_COMPLETE;
Jul 31, 2016, 02:33 PM
awesome and fast working!
sure thing, i can test them.
I got a Naze32 rev6a10dof board.
but then again, its not IBUS per say, its more like a "ia6bus"
Jul 31, 2016, 04:09 PM
NAZE32 Betaflight
Hi,
I hope you can pick up the file. Too large for the forum.
https://drive.google.com/file/d/0B1E...ew?usp=sharing
Jul 31, 2016, 04:15 PM
NAZE32 Betaflight
Hi,
here is a NAZE32 Hex file. Please uncompress before use.
You´re right, I have to find a way to make this special "ibus" selectable, perhabs as cli command...
For this file, you can simply use IBUS receiver type.
Aug 01, 2016, 07:53 AM
naze32 board flashed just fine.
All 10 channels available on the board.
next step is to mount it on my 450 frame and give it a test run.
Cheers and good job androck.
Aug 01, 2016, 02:35 PM
Betaflight 2.9.0
Hi,
something seems to be wrong in my setup with BETAFLIGHT 3.0
For this reason I uploaded a 2.9.0 Version
Aug 01, 2016, 04:36 PM
Ok i reflashed with 2.9 version.
Reception works.
But i still seem to have a problem with the receive rate. (nothing changed from the 3.0 firmware)
it seems like its only updating the inputs at about ~20 fps (wild guess).
(check attached images, there i am jerking the throttle up and down in a smooth manner)
i double checked with the logic analyser and the rate of the packets are still at about every 4ms (wich should give about 400fps at best)
i also double checked with anoter receiver that uses cppm and there the graphs are smooth when i jerk the throttle up and down.
is there some way to log how many packets that failed the checksum ?
or should i go for a more extensive test and check the checksums with an arduino to verify that all the checksums are calculated as i stated before?
i only verified the checksum by 3 or 4 packets when i did it before.
keep in mind, none of the inputs are false, its just that it dont update it as much as i would like to, it will probable be more noticable if you fly with it.
Aug 02, 2016, 12:43 AM
Hi,
the interframe gap was still configured to 3ms for ibus. I don't know if that's correct. IA6B is already ordered
I reduced the gap time to 500us as I can guess from your screens, and it seems to work better.
Thanks for testing with me...
Aug 02, 2016, 05:16 AM
much better!
i measured the timing between the packets and that is a solid 900us.
(no need to upload a firmware just for that but change it for the next one)
Aug 03, 2016, 11:34 AM
I was flying today. Works fine.
Aug 06, 2016, 03:16 PM
PR to betaflight
Hi,
i finally managed to add a pull-request to betaflight:
https://github.com/betaflight/betaflight/pull/1017
If it gets merged, you can set:
set serialrx_provider = IBUS
set ibus_model = IA6
to support our receiver.
Aug 07, 2016, 12:45 PM
really2 great thread, we can use cheap rx
Aug 07, 2016, 01:10 PM
I hope it will be integrated in Betaflight 3.1
If you need another Target than Naze for testing feel free to ask for it.
Sep 28, 2016, 10:18 AM
I noted on the pull request that I'm currently testing it on my SPRacingF3 target. I'd love to see this integrated.
