Sep 17, 2019, 12:32 AM
looking up, down under
scruffy1's Avatar
Originally Posted by nebbian
Try the FS-2A protocol, not FlySky.
and you'll need to flash the recently available protocols to the module, as the fs2a is a late addition, so depending on your multimodule it may not be available
...yet !
however, the required upgrade is not that difficult, and conveniently i have just done it recently, and you can follow my guidance in my blog here :
https://www.rcgroups.com/forums/show...ic-improvement
i'll confirm it works with f2sa once my receivers get here
Sep 17, 2019, 02:27 PM
Thanks for the hint. I tried FS -2A since i can already select it, but i still can not bind.
Settings are:
Mode - MULT FS 2A
Subytype - PPM, IBUS (tried PPM, SBUS also)
Status - no telemetry
Channels - CH1- 16
Rec.-Nr. - 02
Servo rate 50
Is the firmware to old on the module?
Sep 17, 2019, 06:09 PM
scruffy1's Avatar
i'll see what happens when my rx gets here and report back
have you set the correct protocol for the fs-2a ? i think it has more than one option on my "new" protocols
will check after work and comment here
edit :
using the irx4 multimodule i have the subtype options of
ppm,sbus ppm,ibus and also pwm,sbus - maybe that's the magic ingredient ?
i'm updated to Multiprotocol v1.2.1.76
https://github.com/pascallanger/DIY-...odule/releases
