Apr 03, 2017, 11:37 AM
Everything's A Composite
Knoll53's Avatar
Sam, are these planes from the same family or the same neighborhood?
or more directly stated, did you build both of these?
(still hoping for a 4K video of your resdart)
Apr 03, 2017, 03:18 PM
I slope - therefore I am
a944734's Avatar
Blue one is mine, yellow one is my friend's. We tend to build the same planes and fly together often.
Today was very interesting, we flew the Darts on the slope ... Wind was coming rather across but we had a blast with them
Suggest you build one for yourself - you will hardly regret it
Apr 03, 2017, 04:38 PM
Cg
Hi!
If the control surfaces are set according to the manual, the CG of the Res-Dart can be checked that way:
- stable and smooth circular flight with the elevator fully pulled
- hold elevator fully pulled and push maximum aileron in the opposite direction
- rapid, correct reaction - CG too far forward
- sluggish correct reaction - CG ok
- no or inverse reaction - CG too far behind
Depending on weather conditions and your preferred reaction rate, this quick check helps you to set the CG near the position for maximum performance.
I hope my translation is more or less ok.
Franz
Apr 06, 2017, 10:14 AM
Knoll53's Avatar
Originally Posted by resdart
Hi!
Leopold flies Dart:
https://www.youtube.com/watch?v=kffuSAaWt7U
kind regards
Franz
I can see from this video that the Dart flies with significant up elevon when flying slow. In your effort to develop this product, did you experiment with increased wing twist in an effort to optimize this slow flight?
Regards,
Kent
Apr 06, 2017, 03:55 PM
elevon up
Hi Kent!
During the last seconds of the video Leopold did set the brakes. If brakes are set the elevons go up for aditional 2-3 mm.
The normal elevon settings are:
Start: - 0,5mm, Speed: + / -0 mm, Thermik: - 2mm
(minus means up)
kind regards
Franz
Apr 06, 2017, 04:34 PM
More Pile-it than Pilot
mdennis's Avatar
Franz,
Usually in thermal mode, (thermik), you drop the elevons down a little to get more under-camber, which gets you more lift.
You are saying that for this plane you raise the elevons. I would think that would raise the nose.
Is that to slow it down?
Apr 07, 2017, 02:26 AM
compromise
Hi!
The Res-rules don`t allow flaps. That`s why I had to do this compromise. No elevon setting for speed and elevons up for thermal. The wing has its best lift distribution in slow flight with elevons up.
kind regards
Franz
Apr 07, 2017, 07:27 AM
EdSoars's Avatar
Franz, I would like to build a wing similar to the ResDart, but I build in styrofoam with thin skins of some kind, depending on the desired wing loading. I have never built a wing of such low wing loading or high twist. What airfoil should I use to approximate the 'Dart?
ed
Apr 07, 2017, 08:34 AM
Herk
HerkS's Avatar
Ed - you can download the build manual from their website or the link listed in post 75 - it shows the ribs which make the airfoil layout quite clear. I think I saw it on their website. - H
Apr 07, 2017, 10:09 AM
Knoll53's Avatar
ed
There was some discussion regarding the airfoils in the German build thread. If I recall correctly, the airfoils used are proprietary.
Apr 13, 2017, 12:57 AM
Team USA F5J
Jonathan Garber's Avatar
does anyone know what the differences are between the two non motorized versions?
Jon
Latest blog entry: My sailplanes
Apr 13, 2017, 06:06 AM
a944734's Avatar
Jon
Quoting the creator (in another forum)
The German res-rules prohibit DSA-pipes made of CFK. That´s why there is a version with CFK DSA-pipes and a second, RES compatible version, with DSA-pipes made of plywood.
Apr 13, 2017, 07:50 AM
EdSoars's Avatar
Herk, You're right about tracing the airfoil. And Kent, you're right about the airfoil being proprietary. That is why I used the word "approximate" in my request. Franz was kind enough to supply some basic information about the airfoil in a Private Mail. Because the ResDart was designed for competition, the proprietary aspect should be respected.
Of course, anyone can trace the airfoil, and all advances soon become public and widespread. But the ResDart is a lovely advancement for wings as being competitive with conventional sailplanes. As Franz says, it isn't just the airfoil, but the combination of planform, twist, airfoil and weight that make it such a stunning performer.
Ed
May 07, 2017, 02:07 PM
How long servo extension needed for the 4 servo?
What size of spinner can I use for the electric RES Dart?
May 10, 2017, 03:26 AM
Hi villanyie!
Depending on servocablelength you need 2 with about 40 cm and 2 with about 80 cm.
The spinner i use is from aeronaut and the diameter is 38 mm (length 36,5).
kind regards
Franz
Discussion New F3B-RES Flying Wing Model -RES-Dart LSF226 Multi Task F3X 0 Dec 16, 2016 02:23 PM
Contest Dayton Ohio - DARTS – RES/Woody - Saturday/Sunday July 9-10, 2016 Satellite Kid Sailplane Events 0 Jul 03, 2016 11:15 PM
