Feb 10, 2020, 01:17 AM
Some one asked about plans. Yes, plans could be drawn for this model, but, could you cut out the parts? Give the designer credit. The parts in the kit along with the foam jig are absolutely the best possible. He has designed a negative dihedral wing incorporating twist and all of the various features line up accurately. Try doing that manually, making a pencil drawing and then trying to cut to the line.
I like it the way it is!
Bob
Feb 11, 2020, 06:18 PM
OK, I decided to draw up plans that can't be built from but convey the basic outlines and shapes of the model. The rib shown is close but not as accurate as the kit laser version.
Last edited by Bob Reynolds; Feb 11, 2020 at 06:41 PM. Reason: Move plan into print area
Feb 11, 2020, 07:23 PM
RES Dart Drawing
Great job on the drawing Bob. Maybe compufoil could do the ribs. Great job. I found this.
http://www.rc-network.de/forum/showt...Präsentation!?
Feb 11, 2020, 11:57 PM
A rib is easy to draw.
The trick of the kit is each rib is cut with supporting legs in the correct position in regards to the one degree negative dihedral and the five degrees of twist. Note how each rib is correctly located on the foam form. Also note that the ten mm hole is straight and level through its 4 ribs. Tain't easy to do.
Now then, suppose that you make a drawing of each rib per the requirements above and print out those ribs. How thin of a cut line do you need to insure outline accuracy AND then the big question -- Can you cut to the line with your x-acto blade or jig saw? Try cutting the tabs that go into the trailing edge stock.
I have done things like this for some of my models. Very time consuming and nit-picky. I use a very fine jig saw blade while wearing magnification lenses with my eyes about three inches from the blade/cut line. No easy.
Feb 14, 2020, 11:23 AM
Fuse almost done.
55 grams with towhook installed.
Still trying to decide how to do the hatches.
Feb 14, 2020, 12:27 PM
Took franz's advice about shortening the fuse a bit.
Lost another 4 grams, and behind the CG as well.
51 grams with towhook/no hatches yet.
Feb 18, 2020, 05:09 PM
Getting started with first wing panel.
Feb 18, 2020, 11:59 PM
Plan ahead. Get your carbon wing attachments in before the sheeting closes things up. Also make sure that your servo wire can make it through the ribs at the tube /spar joint. Also get the tip connectors built in before sheeting.
Feb 19, 2020, 08:02 PM
Good advice...
I plan on doing all that when the wing is upside down, before bottom sheeting goes on.
Feb 20, 2020, 12:23 AM
While it is still open make up your 4 pin connector with long 3 wires for the aileron/elevator servo and a long enough yellow wire for the spoiler servo. Glue the connector to the wing root with about 10 mm sticking out (inside the body).
Be aware that there may be a clearance problem with the connector and both glass hooks protruding from the wing when you turn the wing over on it's jig mount
Feb 20, 2020, 02:10 PM
Thanks for the diagram! Big help.
Do you have a source for some decent wire? I have some twisted wire but it's heavy guage. Need something closer to the size wire that comes on a D47.
Feb 20, 2020, 09:03 PM
The Lone Sloper
zbytekfr's Avatar
Removed
Feb 22, 2020, 05:52 PM
Fuse is complete.
58 grams. Hatches are balsa with magnetic hold downs.
Feb 22, 2020, 06:25 PM
Top sheeting on right wing panel.
Trailing edge and aileron trailing edge isn't glued on yet. Going to add lightening holes first.
Feb 25, 2020, 05:38 PM
Discussion New F3B-RES Flying Wing Model -RES-Dart LSF226 Multi Task F3X 0 Dec 16, 2016 02:23 PM
Contest Dayton Ohio - DARTS – RES/Woody - Saturday/Sunday July 9-10, 2016 Satellite Kid Sailplane Events 0 Jul 03, 2016 11:15 PM
