Res-dart - Page 10 - RC Groups
Jun 18, 2017, 11:01 AM
dsa-pipe
Hi kinemax!
manual tells that it shall be 133mm beyond LE of rib18 because of F3RES regulations.
This position is also correct for the plywood-pipes and is responsible for the very uncomplicated flight characteristics.
Modifications can be done after a number of flights with two small additional plywood parts. This parts lead to a little better flight-performance by causing a little less forgiving flight-behavior (stall comes later but more intensive). I will send some pictures tomorrow.
In my opinion only experienced res-dart pilots are able to use this slightly better performance and i think that most pilots benefit more by using the unmodified wing tips.
kind regards
Franz
Jun 19, 2017, 01:35 AM
Thank you - this explains my doubts. I'm also interested in this additional mods for future playing, but of course I must learn res-dart first...
Yet another question for e-Res version: What motors parameters are recommended for it ?
I consider making flexible e-fuse with possibility of mounting motor either front or back for tests...
Jun 19, 2017, 05:32 AM
Hi kinemex!
Akku: 450mAh+ (max. Breite 33 mm)
Regler: 12A +
Motor: 2822 KV1400 (2S oder 3S) oder 2822 KV1200 (3S)
Luftschrauben: 9 x 5 / 9 x 6,5 / 9 x 7 / 10 x 8
picture as announced:
Description:
kind regards
Franz
Jun 19, 2017, 06:53 AM
You know nothing....
Stuart A's Avatar
Came across this-
https://www.rcgroups.com/forums/show...1&d=1477856657
Jun 19, 2017, 08:00 AM
Many thanks!
Jun 21, 2017, 11:34 AM
Can't find 38mm spinner for 3 mm motor shaft
Originally Posted by resdart
Hi villanyie!
Depending on servocablelength you need 2 with about 40 cm and 2 with about 80 cm.
The spinner i use is from aeronaut and the diameter is 38 mm (length 36,5).
kind regards
Franz
Hi;
Where did you find your spinner? I ordered the motor suggested on the Hyper flight web site but it has a 3mm shaft and I cannot find a 38mm spinner that accepts a 3mm motor shaft.
MDR
Jun 21, 2017, 02:56 PM
Lost in the Sky
Richard N's Avatar
Aloft Hobbies has 38mm BB Precision Aluminum Turbo Spinners for Folding Props. They come with 4mm collets and 3mm to 6mm collets are available.
Spinners and collets: http://alofthobbies.com/aluminum-tur...ing-props.html
Aeronaut Cam Blades: http://alofthobbies.com/power/props/...t-folders.html
I have ordered from Aloft several times and have received my orders very quickly.
Jun 21, 2017, 03:48 PM
Lost in the Sky
Richard N's Avatar
Scratch Built E-RES-Dart Fuselage
I tried flying my RES-Dart on a high start at the SMALL 2017 Meet a few weeks ago and had some fun but found it too much work and not enough flying. The maintenance to flight ratio for using a glider on a high start compared to the rest of my electric powered models is way out of wack. It takes far too much time to set up and use and take down a high start compared to the tiny effort of charging a motor battery and opening up the throttle. This experience made me decide that my RES-Dart was going to join the rest of my fleet with modern green electric power. Just think how much more fun a Tesla is with electric power than without.
Here is the beginning of my scratch built E-RES-Dart fuselage based on the one described in the RES-Dart Construction Manual V 2.3. It is made of 3mm light plywood and uses the BB-Turbo Spinner and prop blades described in my previous post. The bulkheads are different from the manual. The motor is a Hacker A20-26M that I had on hand. I will leave the tail end of the fuselage open for motor, ESC, and battery cooling. More pictures to come.
Jun 21, 2017, 04:48 PM
More Pile-it than Pilot
mdennis's Avatar
Do you feel like the motor/esc/battery weigh about the same as the weight you had to add in the non-motorized version?
Or do you think you will have to move the battery back towards the CG or more to get it to balance the same as the non-motorized version?
Jun 21, 2017, 05:09 PM
Lost in the Sky
Richard N's Avatar
I did a preliminary check and it looks like the 850 ma 3 cell I am using will be a little ahead of the CG. With the motor, prop, ESC, and a receiver it almost balances. I'm going to use a long hatch piece that goes from the behind the top piece to a little behind the rear wing pin. The business with all the little hatch holes was just too annoying.
Jun 22, 2017, 12:27 PM
Thanks for the tip. I appreciate the info very much.
Regards,
MDR
Jun 23, 2017, 11:18 PM
mdennis's Avatar
Looks great
Jul 09, 2017, 03:26 PM
Mine electro version is flying (pure glider, too..).
It came out a little bit heavy at 660g - 56g motor (red HK 1100kV) needed 1250mAh to make good CoG, but flies very nicely - in fact I like its flying more than 520 pure glider version, but will be using both...
Its agility is fantastic, but costs in low stability (like most of flying wings). Looks like it is flying completely different than other F3RES ships, so the competition may be funny - I plan to use mine in some local F5J if thermals are strong and wind low.
The film is from 2nd day of flying, when my cameraman was available...
ResDart Electro - almost maiden flight (2 min 23 sec)
Jul 11, 2017, 05:14 PM
congratulations
Hi kinemax!
I am glad that your res-darts work well. The high starts and the sink rate of 500 g res-darts are better, but the heavier version behaves more than an airplane, as a friend of mine said to me after he pushed 200 g ballast into his dart and practiced DS.
The weight of my res-dart is about 500g and, depending on weather conditions, i ad up to 130 g of ballast, to influence flight-dynamics.
kind regards
franz
Discussion New F3B-RES Flying Wing Model -RES-Dart LSF226 Multi Task F3X 0 Dec 16, 2016 02:23 PM
Contest Dayton Ohio - DARTS – RES/Woody - Saturday/Sunday July 9-10, 2016 Satellite Kid Sailplane Events 0 Jul 04, 2016 12:15 AM
