Jul 25, 2016, 02:05 AM
Keep Looking Up
BWX232's Avatar
Approved Operating Frequencies
Line Entry Frequency Range Power Output Rule Parts
1 2402.00000000-2476.00000000 0.3020000 15C
https://fccid.io/BRWDAMTX11
So is that 0.302 watts?
edit--
24.8 dBm
(0.302 Watts)
EIRP = 0.479 W
Note 1
https://fccid.io/pdf.php?id=1166228
So 30mw I guess.
Imagine if it was 60! We could only be so lucky.
I do not see FCC ID for "AR6600T 6 Channel Air Integrated Telemetry Receiver (SPMAR6600T)" Or "AR6270T 6CH Carbon Fuse Integrated Telemetry Receiver (SPMAR6270T)" anywhere.
Jul 25, 2016, 02:18 AM
Keep Looking Up
BWX232's Avatar
Maybe we'll be able to program it via bluetooth
https://fccid.io/BRWSPMBT1000
Jul 25, 2016, 02:28 AM
Kambalunga's Avatar
I don't know what for TM1000 you have.
I replaced on one of my TM1000 the antenna, the modul is maked with 17.5dBm.
17.5dBm + 2dBm =19.5dBm
Jul 25, 2016, 02:48 AM
Keep Looking Up
BWX232's Avatar
So does that mean actual output power is 0.479 W? I suppose that depends on where you are in relation to antenna direction.
Jul 25, 2016, 04:45 AM
Kambalunga's Avatar
The TM1000 has a EIRP of ~90 mW.
Jul 25, 2016, 06:26 AM
Keep Looking Up
BWX232's Avatar
FCC says EIRP = 0.479 W.
hmmm....
Unless maybe that is the wrong page.
Jul 25, 2016, 07:58 AM
Sagitta Fanboy
Originally Posted by Kambalunga
On the DX9 too.
That's what I expected, given the 9503's setup. So much of Spektrum's defaults are based on the 9303's behaviour.
Jul 25, 2016, 09:31 AM
Kambalunga's Avatar
hmmm....
The label inside the TM1000 indicate 17.9dBm PEP
Jul 25, 2016, 09:39 AM
AndyKunz's Avatar
Not all are 17.9dBm. Some are higher, some are lower. That's just where this one calibrated.
Andy
Jul 25, 2016, 09:51 AM
Kambalunga's Avatar
A monopole antenna has 2dBm gain then is 17.9dBm + 2dBm = 97mW EIRP
It's look likes for me that the DX9 has a greater telemetry range.
With the DX8 was 700m the edge of range.
Aug 02, 2016, 09:06 AM
have one of each pre-ordered, just to try 'em out...
Aug 02, 2016, 01:18 PM
Hm. I think I will let others do the testing this time. I got so many RX lying around and not enough models to put them in
Aug 03, 2016, 07:17 AM
Fentonflyers's Avatar
Yeah I was going to order as well. Was in the shop and I have about, well, way more than I should. I will wait till I need one this time...
Aug 03, 2016, 08:24 AM
in the grand scheme of things, we don't NEED any of this stuff...
Aug 03, 2016, 09:07 AM
Originally Posted by fizzwater2
in the grand scheme of things, we don't need any of this stuff...
+1000
