Jul 19, 2016, 12:24 PM
New Product
Eachine Falcon 250 Pro - CC3D/F3, 2204 2300kv, 700tvl cmos, 200mw vtx - $220-227
more details: http://www.banggood.com/Eachine-Falcon-250-Pro-CC3D-F3-FPV-Racer-RTF-With-OSD-700TVL-HD-Camera-5_8G-40CH-VTX-p-1069132.html
does not seem that much better than the falcon 250, still uses generic 2204 2300kv motors and non-silab ESCs, camera is once again a CMOS, though at least it can now come with a F3 flight controller
The $220 RTF JJRC JJPro-P200 has much better specs for the price
Item Specification Features
Falcon 250Pro Frame Dimension: 240 x 190 x 70mm
Package : 420 x 270 x 105mm
Weigh: 423g (no battery prop)
Take off Weigh: 535g
Package Weigh: 1.5kg
Compatible with 5 inch propeller
Compatible with 2204 motor
Can be used with 4S/3S battery
With Seft-protection function
With direction indicator LED
Inclined motor base design, fast speed
Removable protection motor base
ESC Model: Fairy-20A
Continuous Current: 20A
Instantaneous Current(10S): 30A
BEC: No
Li-Po Battery: 2-4S
Weight: 7G
Size(without plug): 28 x 15 x 6mm Motor Shaft Lock Protection
(don’t use the other programe, or the funtion will be damaged)
Support OneShot 125
Adopt powerful high performance MCU
Smaller size and lighter
Special for multirotor, more sensitive during flying
Strong adaptive ability
Support the refresh rate of throttle siginal up to 500Hz,
compatible with multi flight controller
(notice:>=500Hz is nonstandard throttle siginal)
Prevent locked rotor protection
Motor KV:2300
MAX Thrust:440G Length: 32.2MM
NO.OF Cell:2-4S Diameter: 27.9MM
Framework: 12N14P Shaft:3MM
Propeller:5-6 inch Weight: 25G
Flight
Controller CC3D / SP Racing F3
Battery 3S 11.1V 1500mAh 35C Battery ,XT60 plug
700TVL Cam Power supply: 3.6-5.5V (powered off TX)
Power consumption: 60mA @5V
Imager: 1/3” CMOS, more than 700TVL
Angle: 127° diagonal FOV, 110° horizontal FOV
FPV tuned light handling
NTSC or PAL (selectable; jumper on = PAL).
Lens: 2.6mm IR coated
FOV: 127°diagonal 110°horizontal (ideal for fixed camera)
Operation Temperature: -20 to 70°C
Square: 32 X 32 X 23.5mm
Lens extrude (LxDia): 15mm X 14mm
Weight: 12g
FT200 VTX Modulate: Wideband FM Modulate
Video Format: NTSC/PAL
Output Impedance: 50 Ohm
Output Power: 23-24dBm
Channel: 40 CH
Operating Voltage: 7V-24V
Supply Current: 190mA
Operating Temperature: -10~85 Video Band Width : 0~8.0 MHz
Audio Carrier Frequency: 6.5 MHz
Video Input Level: 0.8~1.2 Vp-p
Video Input Impedance: 75 Ohm
Audio Input Level: 0.5~2.0 Vp-p
Audio Input Impedance: 10K Ohm
Transmitting distance : ~300m (open area)
LED indicators for Fr/Ch
Connector: RP-SMA Female
Antenna : RP-SMA Male,LHCP
Dimension: 38mm x 22.5mm x 6mm
Weight: 6g (without antenna)
Frequency and channel frequency table:
CH CH 1 CH 2 CH 3 CH 4 CH 5 CH 6 CH 7 CH 8
GROUP
A 5865 5845 5825 5805 5785 5765 5745 5725
B 5733 5752 5771 5790 5809 5828 5847 5866
C 5705 5685 5665 5645 5885 5905 5925 5945
D 5740 5760 5780 5800 5820 5840 5860 5880
R 5658 5695 5732 5769 5806 5843 5880 5917
Eachine i6
Transmitter Channels: 6 Channels
Model Type: Glider/Heli/Airplane
RF Range: 2.40-2.48GHz
Bandwidth: 500KHz
Band: 142
RF Power: Less Than 20dBm
2.4ghz System: AFHDS 2A and AFHDS
Code Type: GFSK
Sensitivity: 1024
Low Voltage Warning: less than 4.2V
DSC Port: PS2;Output:PPM
Charger Port: No
ANT length: 26mm*2(dual antenna)
Weight:392g
Power: 6V 1.5AA*4
Display mode: Transflective STN positive type,
128*64 dot matrix VA73*39mm,white backlight.
On-line update:yes
Color: Black
Certificate: CE0678,FCC
Model Memories: 20
Channel Order:
Aileron-CH1, Elevator-CH2, Throttle-CH3,
Rudder-CH4,
Ch 5 & 6 for reserve Works in the frequency range of 2.405 to 2.475GHz.
Uses a high gain and high quality multi directional antenna
Each transmitter has a unique ID
Low power electronic components and sensitive receiver chip.
AFHDS2A system has the automatic identification function
AFHDS2A has built-in multiple channel coding and error-correction
Eachine iA6
Receiver Channels: 6 Channels
Model Type: Fixed-wing/Glider/Airplane
Bandwidth: 500KHz
Band: 142
RF power:less than 20dBm
RF.receiver sensitivity:-105dBm
Code Type: GFSK
ANT length: 26mm
Weight:6.4g
Power:4.0-6.5V
Color: Black
Certificate: CE,FCC
i-BUS port: NO
Data Acquisition port:NO
Package Included:
1 x Frame Kit
1 x PDB
4 x Motor Base
4 x 2204 Motor
4 x 20A ESC
1 x Flight Controller
4 x Propeller
1 x Power Connector
4 x LED
1 x 3S Battery
1 x B3 Charger
1 x Camera
1 x Camera Mount
1 x VTX
1 x Antenna
1 x Eachine i6 Transmitter
Sep 06, 2016, 09:03 PM
Fly like there's no tomorrow
f5_tornado's Avatar
Reserved for review
Sep 06, 2016, 09:07 PM
f5_tornado's Avatar
Here's 1 out of many mod videos I'll be creating for the Eachine Falcon 250 Pro (EF250P).
IBUS cable from FS-iA6B to SP Racing F3 board (2 min 15 sec)
Sep 06, 2016, 10:30 PM
aka RCFlyer85
Irock1985's Avatar
My Review
Eachine Falcon 250 PRO - Review (Courtesy of Banggood.com) (11 min 43 sec)
My unboxing
Eachine Falcon 250 Pro - Unboxing (Courtesy of Banggood) (13 min 9 sec)
Flight Demo
Eachine Falcon 250 PRO - First Look and LOS Flight (Courtesy of Banggood.com) (6 min 50 sec)
Sep 07, 2016, 01:41 AM
Reserved
Sep 07, 2016, 03:54 AM
Fan of just about anything RC
SoloProFan's Avatar
Specs might be changed before final release, we've seen that happen more often with Eachine.
Latest blog entry: For the love of the hobby!
Sep 07, 2016, 06:17 AM
angelo.p's Avatar
Are bg and Eachine planning to release some sample for review? If yes I'm interested since I just finished to tune the eb185 ��
Sep 10, 2016, 12:50 AM
Would love to test!
Sep 11, 2016, 11:41 PM
Dragon Keeper
dracen knight's Avatar
any idea how much longer before this is supposed to be in?
Sep 12, 2016, 01:26 AM
aka RCFlyer85
Irock1985's Avatar
Are you a tester or did you purchase it?
Sep 12, 2016, 05:15 AM
f5_tornado's Avatar
He's looking to buy it....maybe.
Sep 13, 2016, 07:52 PM
Dragon Keeper
Yep but might be be using stuff gleaned from this site to build my own version.
Sep 13, 2016, 10:29 PM
aka RCFlyer85
Irock1985's Avatar
Oh ok I was asking because it is available for purchase the last time I checked...
Sep 16, 2016, 01:52 PM
Questions about first purchase
I have a small quad I am practicing with, but I've never flown an FPV. I am thinking of trying this out as my first.
I have some questions though.
1. As a first time FPV machine, which controller should I pick? CC3D, Naze32 or SPRF3?
2. If I take off the 10 degree motor tilts, will these motor guards work? I'm worried about how they will interface with the LEDs on the end of the arms.
Finally, of course, any thoughts on whether this is a good first FPV or not? I'm mostly basing my decision on the price and that this seems like a quad that will both work "out of the box" and grow with me.
I plan to just fly it LOS at first and probably buy a screen and/or goggles later. I won't always have access to a spotter, so I may have to use a screen.
My other idea is just to get a Phantom 3 Standard, because who am I kidding? I'll probably crash it once and then just fly it around slowly anyway.
Sep 17, 2016, 12:40 PM
aka RCFlyer85
Irock1985's Avatar
I'd suggest SPRacingF3
Not sure about the motor guards as I don't think anyone here has one yet so can't tell exactly how they're mounted... Hopefully that changes real soon
