Jul 19, 2016, 07:22 AM
No RTF flies like your own SB
mperaltaoz's Avatar
Build Log
Critical Mass Racer - 1200 mm
UPDATE: added decals and updated specs as follows:
Motor: Turnigy 3548 790Kv
Prop: 11x10 2 blades
Much better with this combo
Hi there,
Starting a new project
I've come up with plans in Sketchup based on 3-views for the Hawker Sea Fury and overlapping pictures of the Critical Mass (find plans and capture below).
The specs will be as follows:
Wingspan: 1200mm (approx 1100mm after clipping the wings)
Weight: 1.2kg
Motor: NTM 900Kv
Prop: 10x8 4 blader
ESC: 70A
Battery: 4S 2200mAh
Jul 19, 2016, 08:57 AM
mperaltaoz's Avatar
I've cut and glued the main sections for the fuselage, the cowl and the middle section of the wing.
Photos below.
NOTE: I realised I it cut the fuselage in 3 sections only, as opposed to using all the formers in the plan. I finally did it using only 4 formers as templates: F2b, F10, F13 and F16. That made the fuselage a lot better with less joints.
Similarly, I built the cowl with only 3 formers: F0, F1 and F2a.
Jul 20, 2016, 04:20 AM
Warbirds Lover
Dreamcatcher's Avatar
Subscrived ;-)
Jul 23, 2016, 06:34 AM
mperaltaoz's Avatar
Here's some more progress.
Installed all the internal trays/formers/snakes for servos and pushrods before gluing the two halves together.
Also cut battery hatch and finished cowl.
Looking good.
Jul 23, 2016, 03:22 PM
Build it and it will fly!
Ken Wright's Avatar
Jul 25, 2016, 05:48 AM
Yoyocafe's Avatar
Cool plane!
mperaltaoz's Avatar
I got the wing done now. Sorry forgot to take photos of the parts but it is basically 4 sections and a spar holding them together.
Jul 25, 2016, 08:01 AM
Warbirds Lover
Cool !
You cut a couple of trapezoidal wing pannels then sanded them until you reached the good shape ?
That plane will be lovely ... :-)
Here are a couple of interesting drawings for the paint scheme :
https://www.rcgroups.com/forums/show....php?t=1989769
Have a nice day !
Jul 25, 2016, 08:55 PM
mperaltaoz's Avatar
Basically yes.
I cut the wing tips longer than needed and used a cardboard template for the airfoil. Then i cut them to shape and finally sanded for good finish.
I used this drawings to come up with the plans
Jul 26, 2016, 01:45 AM
Warbirds Lover
Thanks for the Answer Mario,
Very nice job, i look forward the next steps with great interest
Kind regards
Pascal
Jul 26, 2016, 06:12 PM
bstanley72's Avatar
Which NTM 900Kv motor are you planning on using? The 300 watt one?
Jul 26, 2016, 07:00 PM
mperaltaoz's Avatar
No, the 815W swingwing a 4-blade 10x8 prop
Hey, it's a racer after all
Jul 26, 2016, 07:24 PM
bstanley72's Avatar
This is what I was hoping you would say
Jul 26, 2016, 07:45 PM
mperaltaoz's Avatar
LOL...
I used to have that motor on my deceased Gee Bee Z swinging a 12x6 prop and it had a lot of grunt... I'm looking forward to the Critical Mass!
Jul 26, 2016, 07:52 PM
bstanley72's Avatar
Over the last year I've turned my garage into a workshop and I've just started working with a hot wire cutter. My plan all along was to do a couple of easier/simpler builds to learn on, then try to tackle your F4U. However, now I'm thinking this could be my horse!
