Tailfeather Progress
Replacement vertical and horizontal tailfeather cores with Kevlar/glass edging, Kevlar skins and T300 uni-carbon spar caps and waxed and painted mylars.
Donald, and the group.
Looks like this subject fell-off the radar in November. I bought one of these from HobbyKing a few weeks ago and built it using the comments from Paul and the others that were contributing earlier last year. I took it out for its maiden this morning and the the plane flies great. I needed to do some tweaking that I have found to be best done at home, but I am completely happy with his build - more to come as I get it dialed-in John |
Sorry to be late responding, still recovering from a unexpected trip out of town. Here is an update on my Sigma Build:
This is a nice model out of the box there is minimal building/completing to do and it only takes an hour or so of actual time spread over a day to two. Most everything has already been covered in the earlier posts so here are my changes: * used new control wires and sleeves - I used some .032 wire and Teflon sleeve I had on hand rather than the 1mm wire included in the kit. I attached the control wire sleeves to the outside of the tube- personnel preference as I can see that they are secure and not flexing * replaced the plywood motor mount with one that I made out of PC board that was left over from another project. I started with the plywood one but it became more unmanageable as I went along and eventually I chucked it into the garbage can. * paint is Design Mater floral paint which is light weight and is intended for painting foam so there is no danger to the if finds its way through the glass/Kevlar disser cloth The first day out was great and I had a list of tweaks to do when I got home. I saw a "rant" on one of these lists about the constant wind where he was living ... I think that I was in the same situation as it was very windy for days after my first flights. Then I got up one morning and no wind, so off to the field I went. I was having a grand time with the glider - I would launch to about 200 feet and then catch a thermal that would take it to 800 feet or so and then I would dive down to about 200 feet and start again - did this a few times while the wind started to pick up. I managed to get back to the field but a sudden gust of wind (much easier to blame the wind than a lack of visual awareness) came-up and I caught the wing tip on a safety fence on the edge of the field - short version - broke the boom in two but everything else survived with some minor compression creases and scratches. The boom was split as well as broke. I had a few booms that I purchased for an Allegro build several years ago (Goodwinds.com) and with a bit of effort one worked as a suitable replacement (the supplied boom fits nicely on the outside of the pod but the replacement was smaller and fit nicely on the inside of the pod) Here are some photo I took after the repairs. Someone posted earlier that it looks like a enlarged HLG and it does ... I'm thinking that here is too much dihedral (it is very responsive to ailerons but not so much with the rudder) and the vertical fin looks large to me . After flying it a bit more I may reduce the amount of dihedral but in the interim I'm going to have fun flying it. In comparison to other 2 meter offerings, the Sigma appears to me to be good value for the money. |
Can you consistently fly 7 mins or 10 mins after running the motor for 30 seconds? I'm having a hard time doing so.
BTW, I don't think that I could see it if I ran the motor for 30 seconds, perhaps I need to rethink my power set-up |
I'll chime in on flight times.
I usually run my motor for about 15s, which takes me up to 400' (based on my frsky variometer). On a sunny, light-wind day, I can then enjoy about 30 minutes of thermal flying. It depends on my flying style and how sore my neck is getting. Now, remember - I'm a newbie pilot. I'm self-taught when it comes to thermal chasing. I just fly at the same location and tend to know where the thermals like to hang out. Also, I fly at a field that has lots of hawks. I go where they are, while maintaining a respectful distance. I run a very small, cheap 1100kv, gold-can outrunner from HK. I have a 25a speed controller and an 1000mah battery. If I ran the motor full-time, I'd get about 3 minutes of runtime. I have a 3 position switch programed to provide about 5mm of camber or 5mm of reflex. Camber for when I'm in the lift. Reflex when I'm on the move. I hope you all are enjoying this plane as much as I am! |
Finally got around to completing my version (A Dos E from North Planes. Interesting that HK must have flexed its purchasing muscle and driven out North Planes and Hobby Club, who were also importing the identical ship.) with a homebrewed tail group based on the mini-Supra. AUW right at 600 gm with a 3s 1000mah pack. I'll maiden it as soon as it stops raining. Ahh, summer in the Pacific Northwest. |
CG Location
Can someone comment on the correct CG location? Is 50 to 55 mm from the LE as stated in the manual correct? My bird needs as lot of ballast in the nose to achieve that.
John |
Thanks John.
