Jul 15, 2016, 06:47 AM
New Product
Racerstar RS20Ax4 and RS30Ax4 Cheapest & First BLHELI_S 4in1 ESC - Now v2 with BB2
**UPDATE: v1 was BB1 and now there is v2 with BB2 and 30A v2 2-6S version
The 30A v2:
http://www.banggood.com/Racerstar-RS30Ax4-V2-30A-BLheli_S-BB2-2-6S-4-in-1-ESC-Support-Oneshot42-Multishot-for-FPV-Racer-p-1083189.html
The 20A v2:
http://www.banggood.com/Racerstar-RS20Ax4-V2-20A-BB2-48MHz-Blheli_S-2-4S-Opto-Oneshot42-Multishot-4-in-1-ESC-for-FPV-Racer-p-1080541.html
Original v1:
WOW!!!
Banggood jus put out the new: Racerstar RS20Ax4 4in1 BLHELI_S
This is the first BLHELI_S 4in1 ESC, I was waiting for this, I actually waited for the Littlebee pro 4in1 when the BLHELI_S started popping up so I cancelled my order haha... (now have 17 Aikon SEFM 30A and 5 Littlebee 20A-S, yeah i'm an addict)
http://www.banggood.com/Racerstar-RS20Ax4-20A-4-in-1-Blheli_S-Opto-ESC-2-4S-Support-Oneshot42-Multishot-for-FPV-Racer-p-1068210.html
It is now in an amzing price of 27.99$!!! thats less than 4 exreamlly cheap ESC's!!!
Not sure if its BB1 or BB2 MCU
Weigh 19g could be a bit heavier than 4 Littlebee 20A-S which are 4g each
But for the price, who cares, I ordered 2....
Jul 16, 2016, 05:47 AM
RadMulRot's Avatar
What i'd want to know is how much this linear regulator can output?
Jul 16, 2016, 07:39 AM
Sam Richard's Avatar
nothing for the Quad ...
its for the ESC's itself... its a No-BEC ESC...
btw... this is the Martech 4in1
Jul 16, 2016, 08:38 AM
Originally Posted by sevet
WOW!!!
Is this addressable with the pass through programming tools?
Jul 16, 2016, 11:59 AM
I posted this question to the banggood product page, but I'm wondering if the hole spacing is 30x30 or 30.5x30.5?
Also, could someone explain how you would feed 5v to a FC using one of these 4 in 1 esc's? Do you just run the power from the JST harness to a 5v step-down for power?
As has been stated in other threads, I hope they add additional options to these 4 in 1 boards in the future so they can function as a PDB without needing any additional boards...
4 in 1 ESC/PDB and FC/OSD for clean, 2 board max builds please.
I really wish the TBS mini-powercube used on the RotorX atom builds was available separately
Jul 16, 2016, 12:56 PM
It looks like there's a 5v regulator on the bottom of the board and the red/black wires coming out in the JST connector might be the 5v output. Might not be filtered however.
Jul 16, 2016, 02:57 PM
Should work through betaflight pass through,i don't see a reason it won't.
Regarding BEC, the product says no BEC, there probably is a small one since almost no ESC is truly OPTO, might be small drawback without the BEC, it will be good paired with some FC or VTX which has 5v regulator.
Jul 16, 2016, 03:56 PM
RadMulRot's Avatar
Thats the linear regulator on this board.
http://www.datasheetarchive.com/dlma...DSA-311874.pdf
So it likely outputs 5v, through this red wire. Should be safe to power FC from it.
Jul 18, 2016, 05:41 AM
these jst like connectors it has - can many FC can plug in directly? Is this a common connector for the signal/ground/5v plug?
Jul 18, 2016, 10:15 AM
Quadaholic
--Oz--'s Avatar
Bummer, this uses BB1 processor.
Jul 18, 2016, 11:36 AM
Where did you see that?
Is there info on preformance difference between bb1 and bb2? i suspect it is the higher kv motors the question is whats the limit?
Jul 18, 2016, 02:14 PM
Reportbuttonsnitch
Let the master himself speak.
Originally Posted by sskaug
BLHeli_S supports very high motor Speeds. A BB1 MCU will support 350k erpm, and the limit of the BB2 is not yet known, so the code is set to limit at 500k erpm.
Now Rev16.2 firmware is released on github: https://github.com/bitdump/BLHeli
Nothing really significant, but:
- Fixed bug that prevented temperature protection
- Improved robustness to very high input signal rates. 32kHz is now fully supported for BB21 MCUs. For BB10, 8kHz is a recommended maximum
- Beeps can be turned off by programming beep strength to 1
- Throttle cal difference is checked to be above required minimum before storing. Throttle cal max is not stored until successful min throttle cal
Jul 18, 2016, 03:08 PM
So, It seems that this means that currently BB1 is not such a disadvantage after all.
Accept of course for the knowledge that there is something better out there
Jul 18, 2016, 04:37 PM
yes except if you plan on using Raceflight you will want to go BB2 in order to use 32khz on esc which is preferred....
So I take it the Racerstar/Cicada don't have this?
Jul 18, 2016, 06:58 PM
Cicadas are coming out in BB2 versions, but i doubt racerstar rebadge it to a lower price as its a more expensive chip. Who knows these days though.
