Charsoon AntimatterCharger Discharger - RC Groups
Jul 15, 2016, 05:47 AM
Banggood Staff
New Product
Charsoon releases a new balance charger for LiPo/NiCd/PB battery.
And there are quota 5 for the reviewers.
Product link:http://www.banggood.com/Charsoon-Antimatter-250W-10A-ACDC-Balance-Charger-Discharger-For-LiPoNiCdPB-Battery-p-1068233.html
Description:
The Charsoon Antimatter 250W charger is a powerful charger for its size. This high power balancing charger/discharger can provide up to 10A charge rates and handle up to 6S Li-po/LiFe or 17S NiCd/NiMH battery.
The Charsoon Antimatter 250W has great features such as storage charging, cyclic charging / discharging, 10 charge parameter memory and can also be set up as a convenient power supply for a hot wire foam cutter.
Features:
Original Imported Components
This charger use original USA international rectifier and Japan rubycon,more reliable quality.
High Power,High Current,High-Performance Power Conversion Circuit
This charger uses advance Synchronous buck-boost DC/DC converter technology with an output conversion efficiency that can reach over 90%. This is not only save power and reduce heat build up but also makes the charger more compact and conveniently mobile.
Support Many Kinds of Battery
The charger can be used with Lipo,Lilo,LiFe,Ni-Cd,NiMH and Pb battery.
Data Storage
Convenient set of 10 battery profile memories that can be saved and loaded by number,
Various Charging/Discharging Settings and Cycles
For lithium batteries: balance charging,normal charging,fast charging,storage,discharging,ext-discharging,charge/discharge cycling an battery monitoring.
For NiCd/NiMH batteries: charging-auto,charging-manual,discharging,charge/discharge cycling and forming charge.
For Pb batteries: charging and discharging.
Unique Lithium Battery Expanding Discharging Program
When you connect the external capacity resistance,you can use it as the maximum discharge power capacity - 170W(25V/7A).
Unique Lithium Battery Monitor Program
When you use other equipment to charge or discharge a Lithium pack,you can use the charger to monitor the per-cell voltages,battery temperature and process time. If any individual cell appears over-charged or over-discharged or the pack is too hot or the process has gone on for too long,the charge will generate an alarm sound and the related information will blink.
Foam-cut Drive
In this mode,the charge acts as a convenient power supply for a hot wire foam cutter.
Battery Interior Resistance Measurement
The charger can not only measure the internal resistance of the battery pack,and also can measure the per-cell internal resistance (only available for lithium battery).
Perfect Protection Function
The charger has protection for reversed polarity(input or output),low input voltage,battery temperature,charging capacity and time overrun.
English Manual,Click Here
Package Included:
1x Charsoon Antimatter 250W charger
2x Alligator Clips +/-
1x XT60 connector charge lead
1x T connector charge lead
1x JST / Futaba Charge Lead
The reviewers of this product have been selected:
borntoolate
mrforsyth
angelo.p
jdlilfan
ripacheco
Christmas sale:
http://www.banggood.com/2016xmaswish.html?utmid=1209&gasoure=top-logo-2016xmaswish
CyberMonday:
http://deals.banggood.com/deals/edm/topic/CyberMonday2016.html?utmid=1170
Banggood Staff
[Updating]Review of Charsoon Antimatter 250W 10A AC/DC Balance Charger Discharger
Here is some review:
#18 FROM mrforsyth
https://www.rcgroups.com/forums/show...2&postcount=18
#19 FROM ripacheco
https://www.rcgroups.com/forums/show...5&postcount=19
#21 FROM angelo.p
https://www.rcgroups.com/forums/show...5&postcount=21
Charsoon Antimatter 250W 10A Balance Charger Discharger unboxing and review (11 min 31 sec)
#23 FROM jdlilfan
https://www.rcgroups.com/forums/show...8&postcount=23
# FROM nightflyr
http://www.helifreak.com/showthread.php?t=756412
# FROM jhitesma
http://forum.flitetest.com/showthrea...W-LiPo-charger
Very thanks for your support.
Jul 15, 2016, 07:09 AM
angelo.p's Avatar
Hi, I already reviewed the Eachine's Gemini.
Eachine GEMINI 2100 AC/DC 2*80W Dual Balance Charger Discharger (7 min 58 sec)
If you want I can compare the two.
Regards
Jul 15, 2016, 01:25 PM
I suspect that this charger is running Junsi firmware, given that the features are nearly identical to the iCharger 106B+? If so, what version?
After a quick scan of the feature list in the manual, the only absence that I could readily identify is regenerative discharge.
Nice looking charger and a nice price! Much better than typical 4-button chargers, most of which use the same flawed firmware. This would be my charger of choice among those available from BG and a worthy competitor to the iCharger 106B+ and Turnigy Reaktor 250W.
Mark
Jul 15, 2016, 01:54 PM
Does it have HV Lipo charge settings?
Jul 15, 2016, 03:34 PM
Covered on page 3 of the manual that is linked in the opening post.
Jul 15, 2016, 04:36 PM
Hail to the King, baby!
Dragonfish's Avatar
I'd be happy to test and review it for you. If you search my username you'll see I've done a lot of product work for Xtreme-productions in the past. I also happen to need a new charger
Jul 15, 2016, 09:23 PM
Banggood Staff
Hey guys,
I have marked!
Jul 16, 2016, 04:58 AM
Fan of just about anything RC
SoloProFan's Avatar
20W discharge capability sounds nice, do you also have a matching power supply to do a combo test?
Jul 16, 2016, 07:30 AM
Always Building
TheMadCADer's Avatar
I'll review one if you would like
Jul 16, 2016, 08:51 AM
Mark
My thoughts as well. It's either a private labeled Junsi, or a Chinese Junsi ripoff.
Jul 16, 2016, 11:36 AM
Happy to review as well.
Is the USB port active or is it disabled with the lack of serial IC like the Reaktor?
Jul 24, 2016, 10:44 PM
Banggood Staff
borntoolate
mrforsyth
angelo.p
jdlilfan
ripacheco
Jul 25, 2016, 12:54 AM
Bombs away! Err...landing
Ira NZ's Avatar
I bought one of these and accidentally dropped it. It blew up a small moon. Buyer beware.
Jul 25, 2016, 08:25 AM
43 pounds sterling sounds steep as well compared to the 250 Reaktor USD $45.
