Oct 15, 2007, 12:10 PM
Classic jets rule
AIR SALLY's Avatar
thats what i have now...but i had to remove the restictors to get it to work,i dont like them slaming open and shut but that the only way the mech. is strong enough to pull the door shut. the mains are spring loaded shut and the leg opens it ...but i need the rest. removed there also ...just hoping that the tire wont bust through the top of the wing root i'll try and post some vid of it.
Mar 15, 2015, 09:23 PM
Turbobearcat's Avatar
whatever happened with this project?
Mar 15, 2015, 09:48 PM
Pro Hoarder
turbonut's Avatar
Kits were made and sold..
Jun 29, 2022, 12:49 PM
edwen303's Avatar
Hi in the process of repairing one of the earliest? JHH Skyray Anyone has the recommended cg for this bird? In another thread some mentioned 25-28% of the chord from the LE
Temperarily installed 5 blade 70mm fan with Turnigy 28xx 2100kv motor, my goto entry level 6s 70mm fan, ~40 Amp at 22 V. Might try 6s 64mm fan as the exhaust is only 60mm, too small for multiblade 70mm fans but perfect for 6s 64mm 11/12blade fan.
Now working on the nose retract and cockpit, using a Freewing Aa-10 (64mm?) canopy
Jun 29, 2022, 01:04 PM
Pro Hoarder
turbonut's Avatar
Is that the one Chris just sold...Good score
I will check mine and get back to you for the CG..mine is a bit nose heavy as I can slide the battery back with the orig intake design
Latest blog entry: In flight
Jun 29, 2022, 01:43 PM
edwen303's Avatar
Yes guess Chris is busy moving/driving to TN now....
Do you think the cheater hole will help? I cut out a 1 x 1 inch square hole to place my 40-50A ESC, right in front of the fan.
The intake is 1.8x1.8x2 inch triangle, calculated area is ~2000 mm^2 for the twin intake. FSA for a typical 70mm fan with 28mm motor mount is over 3200 mm^2. Am I mistaken somewhere, as the intake area is much smaller than the FSA, meaning the fan is not getting enough air?
This might turn out as heavy bird with small wingspan (still good wing area though)
Jun 29, 2022, 03:29 PM
Ice
Ice
My memory is that I used the c/g as per plans.
Nickel
Jun 29, 2022, 03:46 PM
Pro Hoarder
turbonut's Avatar
I dont know if a cheater is needed..mine gets off the ground pretty good. I am at about 750 to 800 watts on a Eflite fan. Also about 4.3 lbs with battery.
Jun 30, 2022, 02:20 PM
edwen303's Avatar
Maidened the Skyray with mockup cockpit. CG is about ~25% of the chord (wing fuse joint), 2-3 inch forward from the main leg. Servos are the 12 g metal servo (Corona 939 MG).
6s 2200mah 40C pack with 2100kv 5 blade fan, ~900 Watts, ~ 1 kg thrust, auw 1.55 kg (~3.5 lb). She is pretty quick, no bad habit other than prone to rollover when banking angle exceed certain value (where gyro would help)
Discussion "FORD" F4D skyray build thread... corsair nut Pusher Prop Jet Models 1958 Oct 04, 2016 11:49 AM
RBC Skyray F4D Construction Thread FAA Electric Ducted Fan Jet Talk 143 Jul 22, 2016 02:17 PM
Discussion Official F4d Skyray By 6mm Fly Rc Build Thread corsair nut Pusher Prop Jet Models 944 Aug 12, 2010 12:20 PM
Build Log DAG-1 build thread. imsofaman Auto Gyros 36 Jan 13, 2006 09:58 PM
Zuni 1.2M build thread. Botterii Slope Soaring 35 Apr 01, 2004 04:37 PM
