This thread is privately moderated by frank48, who may elect to delete unwanted replies.
Jul 13, 2016, 06:38 AM
Went to mow a meadow
frank48's Avatar
Eachine ProDVR Mini A/V Recorder
Review for Mini DVR
Mine was delivered and I tried it out last night. Needless to say I have had the same results as everybody else...
Only records 640 x 480
Pal problem, cuts off the bottom 2 or 3 lines of my OSD display
If Banggood could fix these problems with a firmware update I think, that on a more positive note, they would be on to a winner.
Its the ideal size and weight for use onboard an aircraft and also works nicely on a ground station or goggles to record your flight and your GPS position in case of a crash.
Just my 2 cents worth, c'mon BG get your finger out and get it sorted! (pretty please)
Specification:
Brand name: Eachine
Item name: ProDVR Video Audio Recorder
Operating Voltage: DC 5V
Video Format: NTSC/PAL
Video Output Size: VGA(640*480px)D1(720*480)HD(1280*480)
Light Frequency: 50HZ/60HZ
Compress Format: MJPEG
Records Frame Rate: 30 Frames
Max Support: 32G TF Card
Weight: only 9.5g
http://www.banggood.com/Eachine-ProD...p-1061196.html
