Jul 11, 2016, 06:17 AM
Zenoaheli's Avatar
Build Log
96 inch Tetris Starfighter F104 - carbon
I just started this kit yesterday,
I will post a lot of pictures as i build
Jul 13, 2016, 08:23 AM
Zenoaheli's Avatar
Pics- last night
She's getting longer
Jul 13, 2016, 09:17 AM
Bronco Team Builder
Wade Joos's Avatar
Looks good
Great job so far with the puzzle
Jul 13, 2016, 09:39 AM
EDF all the way!
bruff's Avatar
WOW!
Bob
Jul 13, 2016, 12:13 PM
4stripes's Avatar
Can you tell us more about what glue you are using? Any helpful tips are appreciated! Are the pieces fitting well and are they the same thickness/height per section?
Thanks Eric
Jul 13, 2016, 01:14 PM
Zenoaheli's Avatar
Hello Eric,
This is my first time so just learning:
west systems epoxy slow cure,
yes the pieces are fitting exactly perfect, i think it was a one piece on the computer then cut by lazer so everything is fitting perfect its left to the builder to get it aligned
Jul 13, 2016, 02:17 PM
Zenoaheli's Avatar
Oh one tip: don't take out the trash until everything is done. So far I had to dig in the trash twice
Jul 13, 2016, 02:23 PM
seeingeyegod's Avatar
So this is a giant 3d printed jigsaw puzzle?
Jul 13, 2016, 02:56 PM
Zenoaheli's Avatar
Foam cut core leaving you free to do what ever you want
Jul 13, 2016, 04:07 PM
4stripes's Avatar
I'm worried about glue being hard to sand. Are you removing epoxy that squishes out with alcohol?
Are you adding any stiffeners like CF or hardwood?
Jul 13, 2016, 04:48 PM
Zenoaheli's Avatar
I'm going to brush epoxy into the joints to hold it all together in different sections
Jul 13, 2016, 05:07 PM
4stripes's Avatar
Aren't you gluing the pieces together with epoxy on the mating surfaces? If so is there no glue coming out when pressed together? I am not sure there will be much strength added by coating the inside surfaces. Just a lot of weight perhaps?
Jul 13, 2016, 05:59 PM
Zenoaheli's Avatar
im using tape to hold it together before i brush epoxy in the seams
Jul 13, 2016, 06:19 PM
4stripes's Avatar
I didn't think epoxy could soak into such fine cracks.
Jul 13, 2016, 06:47 PM
Zenoaheli's Avatar
yes, I will turn the model on its side with slow curing epoxy I believe it will penetrate somewhat.
