Buddy Davis Sport Fish - Page 2 - RC Groups
Jul 11, 2016, 09:49 PM
lots of water; some of it thin
chum444's Avatar
Not yet. Suggestions appreciated. Harbor Models probably a good bet as I understand they purchased the Wet Goose line. I should probably get started before their inventory id depleted. Thanks for mentioning.
Jul 11, 2016, 09:53 PM
Tim B.'s Avatar
Harbor bought out W. G. ???
Jul 11, 2016, 09:56 PM
Tim B.'s Avatar
Catch me if you can !
I want a 28 Center Console !
I know, too short ~
http://www.yachtforums.com/threads/a...dy-davis.3668/
Jul 12, 2016, 04:47 PM
chum444's Avatar
Some early progress. Posterboard trial of deck fit and function. I'm planning on using 1/32 aircraft ply for deck but have concerns about it oil-canning between deck beams. Based on this trial I think it will be okay.
I'm working strictly from on-line photos, trying to estimate proportions of components. If anyone has general arrangement views or even a sales brochure I would greatly appreciate your sharing same.
Jul 12, 2016, 09:22 PM
deck
Looking good! Thats a big boat, I wouldn't be afraid to use 1/16" plywood for that deck.
Jul 12, 2016, 09:45 PM
Tim B.'s Avatar
Looks like a carrier !
Jul 12, 2016, 11:20 PM
Chum444- if you are concerned about the oil canning I would run a bunch of battens between the frames for better gluing as well as strength and support for the decking.
Jul 13, 2016, 06:22 AM
chum444's Avatar
Thanks fg. Was planning to use some battens to add strength to the deck beams. Will expand the number of them if oil canning is a problem. Goal is to keep weight down although I may need a lot of ballast at the end of the day. If that's the case it too will be removable .
Jul 13, 2016, 11:50 AM
Browndog's Avatar
Hatteras set up ,2-12v for the 7.2v for the bow thurster
Jul 14, 2016, 07:21 PM
chum444's Avatar
Looking on opinions for power. I have two Johnson HC 970 motors. Specs on RPM are all over the place but running 7.2V batteries, I doubt if they would generate much above trolling speed. As Browndog reminded me (he also runs 1:1 SF's) these hulls dig a hole and then lift their bow and run at cruising speeds. I doubt the benefit/weight ratio makes the Johnson's practical unless run at 12V & even then scale speed (18-22KTS) would be out of reach. So think a brushless outrunner ( I have specs in mind) is in order. So, first question is:
Forget the Johnsons?
Second question revolves around an Action V-tail mixer. Plan to us it to slow inboard prop in the turn. Data sheet indicates the P40E mixer doesn't play nice with an ESC with a BEC because of potential ground loop interference. Anyone have experience with this mixer and does a BEC cause significant problems?
Jul 18, 2016, 11:44 AM
Hi Chum444
Just starting on the same hull, just finished the 65 Donzi.
Shawn
Jul 18, 2016, 12:35 PM
chum444's Avatar
WIll you do the convertible or the Express version?
Originally Posted by Post 42
Hi Chum444
Shawn
Jul 18, 2016, 06:00 PM
Tim B.'s Avatar
Looks Great !
Jul 18, 2016, 07:48 PM
profile
great profile!
