FZ6: Building! - Page 5 - RC Groups
Oct 03, 2016, 04:34 PM
InceCreations
vincent123's Avatar
Blended wing body design ?
just blended the batteries out
Oct 07, 2016, 02:30 PM
InceCreations
vincent123's Avatar
Wing estimate, without fuselage
1235gr including EDFs and motors
835gr without EDF and motors
of which 200gr is carbon (50gr per carbon spar x 4)
I could shave 50 gr by reducing the carbon thickness, this woud reduce the max. G's from 18G to 14G.
Any thoughts ?
Oct 07, 2016, 03:19 PM
iron eagle's Avatar
Actually your weigh doesn't seem all that bad.
I thought you had planned on a AUW of 2900 g for that wing area anyhow?
If there is a real possibility if it going to be a fast airplane, stick with the stronger setup, it will resist "Body Freedom Flutter" a lot better. And flutter with a flying wing can be a real killer.
I did have a thought regarding servos and control linkages. If you could move the engine nacelles a bit further outboard (where the wing bends downward) you could incorporate the servos,horns and linkages within the engine nacelle much in the same manner I did with my delta with the pull pull linkages.
Oct 07, 2016, 03:57 PM
InceCreations
vincent123's Avatar
AUW is about 3000gr, but possibly I'll end up a bit more.
Nevertheless, I should have more than 4000gr of thrust. So that's ok, and with the FZ5 experience, I learned in fact that weight is not 'that' much important: the FZ5 wing is more than capable to carry his weight and flies very light weight.
The servo setup is is my classic approach, I'll take the HITEC HS-5070MH.
Just done estimating wing COG, seems I have to push the batteries 60mm up front to get even balance: or I extent the fuselage , resulting in a higher nose leg wheel, has its limits, or I make the fuselage wider to acccomodate 2 batteries side by side..., or I take one big battery .. hmm
Oct 08, 2016, 08:06 AM
InceCreations
vincent123's Avatar
Ha, found a solution !
shifted the ESC's below the battery, so I can leave the battery where it was !
Oct 08, 2016, 08:39 AM
You know nothing....
Stuart A's Avatar
Neat!You should be able to get some airflow over them in that position.
Oct 09, 2016, 04:11 AM
InceCreations
vincent123's Avatar
Thx, Stu.
Any ideas about the vertical empennage ?
Sizing is about double for what I would normally take as winglet.
Moment arm to CG, taken in order to have the same stability index (p 190 Taileless tale) as what I would take for winglets ...
So this should result in a good directional stability.
Oct 09, 2016, 06:56 AM
InceCreations
vincent123's Avatar
Vertical empennage is 40mm at the base, airfoil planform, too thick ?
Oct 09, 2016, 08:23 AM
Stuart A's Avatar
Here's a link I came across a while ago
http://www.charlesriverrc.org/articl...ilairfoils.htm
Sounds like the thinner the better,bearing in mind the structure needed.
Oct 09, 2016, 09:53 AM
InceCreations
vincent123's Avatar
Great Stu, I immediately applied the H14 profile, wingbase of the VT is now 30mm
Oct 09, 2016, 02:15 PM
iron eagle's Avatar
Now that looks like a hot airplane!
Oct 09, 2016, 03:42 PM
InceCreations
vincent123's Avatar
Ok, thanks !
Oct 10, 2016, 03:27 PM
InceCreations
vincent123's Avatar
Can't do it, the airfoil is too thin and the thickest point is too close to the LE. Got difficulties to model it, so that I can make it in a decent way.
Thinking of the NACA 0009 as an alternative
Oct 12, 2016, 02:43 PM
InceCreations
vincent123's Avatar
Not easy to model a narrow sweeped vertical stab.
Took the NACA0009
Anchoring in the fuselage is for later.
Oct 15, 2016, 10:52 AM
InceCreations
vincent123's Avatar
Ready to start designing the formers and battery plate of the fuselage...
