Sep 04, 2016, 03:36 PM
InceCreations
vincent123's Avatar
Hi there,
was thinking at the braking issue during landing.
While the EDF's are pretty close to the fuselage, flaps are a no go.
Any ideas how I can brake the best way (MIG15 style?)
Sep 04, 2016, 03:49 PM
Herk
HerkS's Avatar
I would not write off flaps at all. A segment of the flap inboard of the nacelle and another outboard of it still leaves plenty of room for effective elevons --IMHO of course
Sep 04, 2016, 04:13 PM
You know nothing....
Stuart A's Avatar
Also the type used here-
http://www.luft46.com/gotha/gop60a.html
Sep 05, 2016, 12:30 AM
InceCreations
vincent123's Avatar
Originally Posted by Stuart A
Drag things at the wing tip you mean
So this brakes and leaves lift unharmed, right?
Sep 05, 2016, 02:08 AM
Stuart A's Avatar
There are twin flaps/air brakes at the rear of the underbelly,angled at 15*
Sep 05, 2016, 11:57 AM
InceCreations
vincent123's Avatar
Oh, i did not notice them, I thought you talked about the drag rudders.
Sep 05, 2016, 01:35 PM
InceCreations
vincent123's Avatar
To what extent do I have to exclude the wing span covered by the EDFs?
I mean the EDF's take about 2 times 80mm of wing span.
This wing span does not have a nice wing profile, so the effciency will be lower compared to a normal wing without EDFs build in?
Into the calculation of:
Aspect ratio
Wing loading
Do I exclude this 160mm wingspan for these calcs?
Sep 05, 2016, 02:12 PM
Herk
HerkS's Avatar
Aspect ratio
Wing loading
Normal aero practice is to include the projection of the wing that passes through nacelles and the fuselage.
Sep 05, 2016, 02:18 PM
Is this still supposed to be a seaplane?
Beriev A-150:
hhttp://i1147.photobucket.com/albums/o557/Horseformer/AI/Beriev150.jpg
Beriev apparently had some other delta wing jet flying boats too.
Convair Sea Dart:
https://en.wikipedia.org/wiki/Convair_F2Y_Sea_Dart
Yes, it does have two engines.
Sep 05, 2016, 02:38 PM
InceCreations
vincent123's Avatar
Beriev A-150:
Convair Sea Dart:
The sea dart is crazy !
The FZ5 flies so well with his EDF that I left the see plane idea and went for a double 70mmEDF setup (for now at least, see how far I get with it)
Sep 06, 2016, 02:18 PM
InceCreations
vincent123's Avatar
Thanks Herk, makes things easier.
Any thoughts when looking at the planform?
Flap is 100mm length, so i believe it will brake.
Alevons 325mm.
As the wing has 33° sweep, the anhedral of 6 degrees at the wing tip will not harm. Correct ?
Dihedral due to sweep at landing is about 16° -> still 10° positive
Dihedral at speed is about 4° --> -2° negative
So in theory at speed I have no dihedral effect. What are de drawback?
Spiral instability ?
Sep 06, 2016, 03:12 PM
iron eagle's Avatar
You will have no problems as far as spiral stability with this from what I can see.
Nice looking airplane!
I would make the wing a bit thicker at the root end, those fans are going to put a fair amount of stress on the fuselage wing joint.
Sep 08, 2016, 01:55 PM
InceCreations
vincent123's Avatar
Construction wise is not at the order at the moment, first looking for a good planform ..
Some more pictures taken on the runway
A wingtip of only 30mm seems enough for the skids.
Perhaps i ll suck some grass but i believe it' s ok
Sep 09, 2016, 03:56 PM
InceCreations
vincent123's Avatar
Thinking about making the skids more stylish, but how am I gonna be able to make this ?
Sep 09, 2016, 04:02 PM
Stuart A's Avatar
Nylon 3D print?
