FZ6: Building! - Page 14 - RC Groups
Mar 11, 2017, 03:16 PM
InceCreations
vincent123's Avatar
Yeah looking forward to it,
thinking of printing the bone structure with space for carbon spars and all.
But still finish it with balsa planking and sheeting. Cause a plastic plane looks kinda cheap ...
but first finish this project, otherwise it will never get finished !
Apr 10, 2017, 05:08 AM
InceCreations
vincent123's Avatar
Right wing
Short update on the right wing progression.
Happy it builds a tiny bit faster.
Apr 10, 2017, 05:58 AM
You know nothing....
Stuart A's Avatar
Nifty use of the blocks and rubber bands!Those long jawed clamps look to be a handy piece of kit.
Apr 10, 2017, 11:23 AM
InceCreations
vincent123's Avatar
Realy need to get that magnetic building bord to work
Apr 11, 2017, 12:54 AM
iron eagle's Avatar
It looks like your managing quite well without a magnetic board. The structure of those wings are quite an artwork!
Jun 27, 2017, 01:11 PM
InceCreations
vincent123's Avatar
Now you know why my focused shifted a bit
Quake Champions Gameplay - Duel (15 min 16 sec)
Jul 01, 2017, 04:57 AM
Stuart A's Avatar
Haven't you cracked your game yet
Aug 15, 2017, 03:53 AM
InceCreations
vincent123's Avatar
Both wings are in the same stage now: bottom side planked, top still to be done.
Root sheeting only when the fuselage is ready, so I can make the sheeting flush with the fuselage sheeting.
Sep 09, 2017, 04:55 PM
InceCreations
vincent123's Avatar
Ducts both closed now, inner and outer duct fully sheeted and sanded.
Tested the EDFs once more: looking good, each pulls easily 60Amps at 6cell, good for about 2kg thrust each.
I believe this will increase a bit or a lot (?) once I sanded the inlet lip.
But for this I need to finish the sheeting of the wings first.
Sep 11, 2017, 07:55 AM
Stuart A's Avatar
Looks like you've got another winner on your hands.Have you worked out the projected final weight?
Sep 11, 2017, 02:16 PM
InceCreations
vincent123's Avatar
Hi Stu, I did an estimate and it would end up at about 3400gr ..
Of which 1000gr is battery
380gr are 2 engines and 2 EDFs
210 gr for the 2 ESC's
and about 100gr nose lead
The CG location is designed as I finally did for the FZ5, so the fuselage is counted for.
Nevertheless, I do not know what the effect will be of the nacelles.
I'll try a mockup on the prototype and glue a bulge on top of the wings, to check their effect on lift and CG ..
Sep 14, 2017, 12:32 AM
iron eagle's Avatar
I do not think you will have any issues as far as thrust. I wouldn't be overly concerned with your static thrust measurements, I suspect the thrust will be much higher when your airborne.
I do not think the nacelles will cause any noticeable shift in cog or the center of lift.
Sep 14, 2017, 03:00 PM
InceCreations
vincent123's Avatar
All good!
Oct 02, 2017, 10:11 AM
InceCreations
vincent123's Avatar
After a lot of preparations, the third sheet (of 8!) got glue today
First the LE was glued in place.
I use a kind of a frame to prevent the wing from warping when the sheeting is glued.
Oct 02, 2017, 12:42 PM
Stuart A's Avatar
I like the hooked frame!Very inventive.
