Jul 09, 2016, 06:37 AM
InceCreations
vincent123's Avatar
Build Log
FZ6: Building!
Looking for a new project.
Are there any flying wings pictures available as a waterplane ?
Jul 09, 2016, 08:04 AM
miniphase's Avatar
Burgess Dunne perhaps?
Jul 09, 2016, 09:58 AM
Person of interest
KiwiKid's Avatar
A few ideas here: https://www.rcgroups.com/forums/show....php?t=1067631
This one looks up your alley
https://www.rcgroups.com/forums/show...&postcount=387
Jul 09, 2016, 12:09 PM
less is more
Knoll53's Avatar
I would think that designing a seaplane hull would be right up your alley. Getting the step in the hull in the right location would take some research, but your wings look to be already well suited. Your turned down winglets could be pontoons. I can imagine some good ground effect landings over water.
Jul 10, 2016, 01:49 AM
InceCreations
vincent123's Avatar
Originally Posted by KiwiKid
Good tip, looks easy to make, kinda like the North Star.
Jul 10, 2016, 01:50 AM
InceCreations
vincent123's Avatar
Yeah, could take the FZ3 design and make the fuselag hull a bit higher so it acts like a float...
Sep 03, 2016, 02:59 AM
InceCreations
vincent123's Avatar
Any potential?
Sep 03, 2016, 06:43 AM
InceCreations
vincent123's Avatar
My son designed his proposal, he is 12 !
Sep 03, 2016, 09:18 AM
Herk
HerkS's Avatar
What is it that you want this new concept to do?
Very high speed flight -- or acrobatic flight -- or just an all around fly for fun model ??
Or something else?
Sep 03, 2016, 09:27 AM
InceCreations
vincent123's Avatar
Design specs (for change as we go along):
- runway take off
- nose wheel and tip skids preferred
- high speed welcome, but
- overall design has to appeal, example FZ5: good looking, fast and flies easy
- 2 ducted fans 70mm, each 2kg thrust, 2 batt of 3300mAh, each 500gr, total weight 2.5kg (my alltime high)
Sep 03, 2016, 10:33 AM
You know nothing....
Stuart A's Avatar
That looks very promising!(have you been browsing Luft46?)
Sep 03, 2016, 11:18 AM
InceCreations
vincent123's Avatar
So obvious ?
Sep 03, 2016, 03:21 PM
InceCreations
vincent123's Avatar
First attempts ..
Span about 1300mm, for transport thinking of having the dropped down ends loose (and secure it with a servo?)
Sep 04, 2016, 08:50 AM
InceCreations
vincent123's Avatar
Side by side with FZ5, looks not bad !
