Firefly Q6 - 4K 24fps 12MP Bring that competition! - Page 5 - RC Groups
Aug 04, 2016, 04:17 PM
Adam
xStatiCa's Avatar
I use this stuff on some electronics I think might get sprayed by salt water. It works great to protect them in my experience. It is hydrophobic and repels water. I have dunked a little toy in water before with this sprayed on all exposed electrical parts (including battery ends) and it kept working while under water. I don't recommend that though .
Corrosion Block
http://www.westmarine.com/buy/corros...04_129_004_507
Here is a newer product which claims to have similar properties...
http://www.hzo.com/
Aug 05, 2016, 06:23 AM
RC Crazy
billhally's Avatar
I would be really worried about covering up the ventilation holes or slots, these small camera's have a powerful processor in there that given its capabilities gets pretty hot and breathing is of major importance for it. The camera case was designed this way for a reason and the reason is heat.
Bill
Aug 05, 2016, 11:28 AM
Flying while Frying
Originally Posted by sureshot__
So - If you need WiFi, look at the new Firefly 7S
Any other 2k or 4k with wifi but with the Keychain shape similar to this one?
Aug 05, 2016, 04:10 PM
I was thinking of the same, but haven't found anything in this category.
Anyway, I need a cam soon, hence I've ordered the Q6.
I hope I can achieve something similar by tethering (playback, framing, etc.)
Aug 06, 2016, 01:11 PM
RC Crazy
billhally's Avatar
A test flight into the sun on a misty morning
A misty early morning Skywalker flight testing the Firefly Q6 camera. (10 min 13 sec)
Bill
Aug 06, 2016, 10:07 PM
ptg
ptg
#1
Nice, calm day for testing.
Very steady footage.
Q6 Image stabilizer on?
Aug 06, 2016, 11:56 PM
https://www.youtube.com/watch?v=bjHgQZUgxXM
Bill
well not bad but the WDR looks really really bad
the sky looks white on the left side .
Would be interesting to know the bitrate in 1080p 60fps
Aug 07, 2016, 01:13 AM
sureshot__'s Avatar
The Foxeer legend 2 has WiFi.
Of course WiFi will drain the internal battery sooner, so you may want to power it from the flight battery
http://www.banggood.com/Foxeer-Legen...p-1053384.html
I hope to have my Q6 flying tomorrow.
-Bill
Aug 07, 2016, 08:08 AM
RC Crazy
billhally's Avatar
I did not have WDR turned on during this video, all around there was a strong ground mist rising which made everything look white too and bitrate was in High and is 37000kbps.
Aug 07, 2016, 10:19 PM
sureshot__'s Avatar
The FPV view?
I updated the Q6 to ver 2.1.
The CX-20 is repaired and the Q6 is mounted & gimbal re-tuned.
Somehow my FPV screen is B&W - no color?
While poking around trying to see color on my FPV screen, a WiFi symbol appeared.
I have discovered that Gyro & Anti-fisheye do work simultaneously.
I like that the FPV view shows mode and a blinking dot while recording.
Now, if I can just get the live out to show in color...
https://www.dropbox.com/s/onvtz1938n...t%203.JPG?dl=0
-Bill
Aug 08, 2016, 12:15 AM
ptg
ptg
#1
-Bill
It is all in your monitor settings.
You must try different settings on your monitor (PAL, SECAM etc, etc...)
Aug 08, 2016, 06:56 AM
RC Crazy
billhally's Avatar
Totally agree.
Bill
Aug 08, 2016, 07:08 AM
cyberbillp's Avatar
Originally Posted by Maven2007
WiFi is needed for config, preview and start, stop. Without it, you don't even see what you record and how camera is positioned. WiFi is a must. It is not only about start and stop recording.
Keychain size is ideal for detectives, any kind of surveillance, monitoring work.
To me WiFi feature with live preview is a must.
WiFi interferes with just about everything rc.
2.4 messes with controls, 5.8 trashes your video. So "no wifi" is a good thing.
Aug 08, 2016, 09:19 AM
ptg
ptg
#1
Only if you use cheap components.
Aug 08, 2016, 11:48 AM
sureshot__'s Avatar
So far I have reloaded 2.1 software.
To rule out TX, RX, & OSD issues I wired the video signal direct from the Q6 to the monitor.
The picture was still B&W.
I Tested the monitor directly from the old Runcam & it showed color.
