Mar 10, 2017, 09:44 PM
Reference
V2.5 version
  • 2017-02-09
Default => reset settings
  • Yes
  • No
Format
  • Yes
  • No
OSD
  • On
  • Off
LED
  • On
  • Off
Beep
  • On
  • Off
Battery standby 3 minutes
  • On
  • Off
Date and time
  • Y M D H M S
Battery show
  • On
  • Off
Angle => digital zoom on Middle
  • Large
  • Middle
Power off by usb => 30 seconds after disconnecting
  • On
  • Off
Gyro => digital image stabilization
  • Off
  • On
Remove fisheye => no effect with 90 degrees lens
  • Off
  • On
HZ => light frequency
  • 50 hz
  • 60 hz
TV mode
  • PAL
  • NTSC
Date stamping => Firefly Q6 YYYY-MM-DD HH:MM:SS
  • On
  • Off
Data rate
  • High
  • Low
Long exposure
  • Off
  • 0.5 sec
  • 1 sec
  • 2 sec
  • 5 sec
  • 10 sec
  • 20 sec
  • 30 sec
  • 60 sec
Metering
  • Average
  • Center
  • Spot
Contrast
  • High
  • Medium
  • Low
EV
  • High
  • Medium
  • Low
Color
  • Standard
  • Vivid
Sharpness
  • High
  • Medium
  • Low
ISO
  • Auto
  • 100
  • 400
  • 1600
Photo interval
  • Off
  • 3 sec
  • 5 sec
  • 10 sec
  • 30 sec
Photo burst => 11 in a second
  • On
  • Off
Photo size
  • 16 MP
  • 8 MP
  • 5 MP
Frame first => force 60fps in low light
  • Off
  • On
Slow motion video => overrides Video Size, slows down 4 times to play back at 30fps
  • Off
  • 720p-120fps
Microphone
  • On
  • Off
Rotate => 180 degrees
  • On
  • Off
WDR
  • On
  • Off
Auto record video => only when USB powered
  • On
  • Off
Cyclic 5min => Off cycles at 4GB file size, On overwrites oldest file
  • On
  • Off
Video timelapse
  • Off
  • 0.5 sec
  • 1 sec
  • 3 sec
  • 5 sec
  • 10 sec
  • 30 sec
Video size
  • 4K 24fps => 2880x2160 ... ... ...
  • 2.5K 30fps => 2560x1440
  • 1440p 30fps => 1920x1440 ... not THE 1440p
  • 1080p 60fps => 1920x1080
  • 1080p 30fps => 1920x1080
  • 720p 120fps => 1280x720
  • VGA 30fps => 640x480
Mar 10, 2017, 09:55 PM
Request #1: I need auto record on battery, soon otherwise this gets returned
Request #2: more choices for battery standby, Off-1-2-3...minutes
Tip #1: move slow motion 720p 120fps under video size, it is a mode, not a setting
Tip #2: make ON/OFF order uniform across settings, not ON/OFF and the next OFF/ON. I suggest OFF first to match settings with number values
Tip #3: set your strings/variables right, DEMO1 looks bad (image)
Problem: now taking 16MP pictures instead of 12MP in previous firmware, developper error?
Mar 11, 2017, 10:16 AM
Originally Posted by SgtSardine View Post
Does this camera have a software narrow FOV option? Thanks in advance.
yes, in Angle setting.
Mar 12, 2017, 01:58 PM
The smallest bug: after taking a picture, the Large/Middle angle symbol disappears
Mar 13, 2017, 02:11 AM
Race Miata's Avatar
Without the bitrate-demanding grassy field background, I don't have to post-process my onboard footage to prevent Youtube from macro-blocking it to death with its low bitrate recompression.
My MS2204 Chase-View Cub at the Demolition Derby track (4 min 58 sec)
No problem even with fast-moving scene like this. Sure if you pause the video and look for details on the gravel it's not the best, but the strength in 1080p60 video is details in the time domain. If you can play the video without a single frame drop, the smoothness of the video and the details in the object movement cannot be achieved with 4k24p mode which is like stop-motion animation and useless with such fast-moving scene.
My MS2204 Doing Demolition Derby Track Under the Bridge (3 min 12 sec)
I think this cam handles light/dark scenes pretty good with such challenging condition (quickly changing between bright sky and dark bridge/ground). No post-processing has been done in either video except turning down the volume.
Mar 13, 2017, 10:47 PM
Q6 led screen replacement
Recently my quad dropped into water together with my Q6, after cleanup with 75% alcohol and drying, the lcd was not working but the camera still able to record. So I ordered a lcd replacement from gearbest and replaced the led, see pic below, I think my soldering looks okay. But the new lcd still not working. May be it is something else that causing the problem. Eg a burned cap? Anyone know what I should be for in the PCB?
David.
Mar 13, 2017, 10:53 PM
DWKC's Avatar
I mean what I should be looking for in the PCB to ID the screen problem?
Mar 17, 2017, 07:51 AM
andrewbt's Avatar
Hi, is v2.5 the latests firmware for the Q6? i noticed that v2.4 has a newer build date http://www.cnfpv.com/en/TECH/164.html
Mar 17, 2017, 08:22 AM
I COLLECT flyaway&lost drones!
martin555's Avatar
I dont know but
FIREFLY 7S ???? w.t.f.????
3.Put the tf card into FIREFLY 7S (make sure battery > 50%)
Mar 17, 2017, 08:54 AM
........... i noticed that v2.4 has a newer build date.....]
.FW v2.4 was never published before. But some Q6 was delivered with it.
Maybe that is the reason of the newer date.
Changelog is missing too.
Mar 17, 2017, 09:46 AM
that's good idea
that's good idea
Mar 19, 2017, 02:49 PM
Sail or Fly Guy
roehrle's Avatar
Lens cover ??
Does the Q6 come with a protective film on it ?? I just got mine and it seems to have a slight blur to the video like there is a cover on the lens .
Mar 20, 2017, 04:53 AM
Race Miata's Avatar
Mine didn't. If it did, it would've been very noticeable or else I would've remembered strongly of bitching about it.
Mar 22, 2017, 02:04 PM
Firefly Q6 v2.4 for whoever wants it
LINK HERE
Mar 22, 2017, 02:12 PM
What settings everyone using on there Q6?
New Product [$68.9 NOW!] Hawkeye Firefly 7S 2160P 24FPS WiFi FPV Action Camera with IMX078 HezarfenF16 FPV Equipment 27 Today 08:03 AM
New Product FIREFLY 6S 4K - finally some 4k competition tvdrone Aerial Photography 214 Yesterday 01:58 PM
Discussion FIREFLY Q6 - 4K 24fps 12MP Sony IMX078 Novatek 96660 portable size Firebird_PL Aerial Photography 60 Feb 12, 2017 05:21 AM
Mini-Review HawkEye Firefly 6S 4k (2160p) vs Firefly 5S 1080p Comparison Sunny_1 Aerial Photography 2 Nov 09, 2015 04:29 PM
