Wingspan: | 1400mm (55 inches) |
Flying Weight: | 890 grams (31 ounces) |
Length: | 1036mm (41 inches) |
Transmitter: | Minimum of 6 channels |
Receiver: | Minimum of 6 channels |
Battery: | 3s 2200 25-40c |
Power system : | 2212-1350KV motor, included |
ESC: | 30amp, Included |
Typical Flight Duration: | Depends on available lift, but I easily got 15 minutes |
Available From: | HobbyKing |
Price: | $107.07 at the time of this review |
The HobbyKing Walrus has been around for 4 years, and in that time it has become a favorite for many. With good flight characteristics, and a full house set up (yep..it has flaps!) in a 55 inch wingspan, the Walrus seems like the perfect plane. However, as with most things, there was room for improvement. You see, the problem with the Walrus was when the sun set, the fun was over. Not anymore! HobbyKing has added LED's as well as a few structural updates so you can continue flying well after dark.
Hobbyking Night Walrus - RCGroups Flight Review (6 min 7 sec) |
In addition, HobbyKing also supplied a FrSky X6R receiver
Additional parts I supplied to complete the build:
Not much to say here..a Phillips head screwdriver, a pair of needle nose pliers, and glue (I prefer Foam-Tac) are all you need.
In order to complete the build, you simply install the control horns and clevises, glue the empennage in place, and finally, slide the wings into place and secure them with the included screws.
The motor and the ESC are pre-installed, so the only wiring you need to do consists of plugging in the LED connections to the surfaces, and of course hooking up servo's to your RX as you assemble the Night Walrus.
The Night Walrus features plastic "skid plates" pre-installed on the fuselage where it will come in contact with the ground during landing. This is a nice touch and is direct response to feedback received from the original Walrus.
The LED's are embedded in the plane, resulting in a nice glow that isn't going to blind you if you are flying "slow and low." Personally, I appreciate this approach, as it saves the pilot's eyes, as well as the eyes of those who may be flying with you
Launches are easy, just throttle up and give it a toss. The climb-out is solid, and half throttle is all you need for a successful launch. Before takeoff, I had added a bit of up trim to insure a good launch. As it turns out, this wasn't needed. I did have to add a little right aileron trim, it ended up being 3 click's worth. Flaps, rudder, and elevator needed nothing. Controls throws felt great on the recommended high rates, though I do want a bit more aileron.
I did some basic aerobatics, and the Night Walrus took them all in stride, and looked good at the same time. One thing that surprised me was how quick the Night Walrus is. Most of my flying was at or below half throttle, but I did open it up a few times and I was pleasantly surprised at how quick it is. My camera person, on the other hand, wasn't as impressed, since fast flight made it hard to keep up with!
Landings are simple, with or without flaps. The plane carries speed well, and floats like you would expect from a sporty glider. Flaps are effective, and though you don't need to use them, they sure do add to the fun of short field night time approaches!
I like this plane a lot. Good looks, a great lighting scheme, and rock solid flight performance make the Night Walrus a plane that will get a lot of flight time. The build is fast, from the box to flight ready took me an hour. The colorful graphics are complimented by the internal LED's and make for a very easy plane to see at night. The wide speed range make it great for lazy flying as well as spirited passes down on the deck. Add to that the easy launch and landing characteristics, as well as "full house" controls, and you have a winner. The Night Walrus will be in the truck every time I head out!
I would like to thank Stuart at HobbyKing for providing the Night Walrus for review, my wife for photos and video, and Jim T. and Matt Gunn for their assistance as well.
Nice plane, curse you and HK for putting this in front of me not long after several planes left and made room for it.
Couple questions: 1- How convenient is this to transport? Does it break down quickly and easily or even go back in it's original box? 2- How is the hardware quality, I ended up sourcing replacement screws for a number of the Tundra parts, wondering how this is. 3- How easy is it to tell up from down in full darkness conditions? A lot of my planes that glow internally and are fairly symmetric it can be difficult to orient when rolling. This one has a lit vertical stab that appears to be the only visual clue when night flying. 4- How feasible is this to dive down to a very small field in a residential subdivision at night? It will glide forever but bringing it down safely in tight quarters may allow me to fly it more frequently. |
Latest blog entry: Ultra configurable plane storage rack
1: Since the tail surfaces are glued on, it won't go back in the box. The wings come off with the removal of 2 screws, and disconnecting the servo and LED connections. The only difficult part is threading the wires back into the fuselage, but that could be made easier with longer "Y" connections.
2: The only hardware you have to remove and install when breaking down are the wing screws. Those are machine threaded, and of good quality. I'll get a measurement this evening, and let you know the diameter, and the thread pitch if I can find my pitch gauge 3: Pretty easy..the vertical is lit, and the cockpit has white LED's in it, shining up through a frosted canopy. Also, the wings are lit Red and Green, red on the left and green on the right..that alone makes it easy to tell if you are upside down or not. 4: With full flap, you could get it in a pretty small area with some practice. I would recommend trying some approaches at your regular flying field during the day to get a feel for it. One thing to keep in mind is since you have flaps and ailerons, you can set up a "Crow" mix and really slow things WAY while keeping a steep descent angle. That will help with short field landings as well |
Latest blog entry: Intro..a few years to late!
The wing bolts are 3mm x 50mm , machine thread, like I mentioned earlier. I just ran mine in and out several times a few minutes ago without a problem..
Are the lights always on? Or can you disconnect them during daylight flying so as not to have an unnecessary drain on the battery?
The lights can be disconnected easily.
Latest blog entry: 93" AJ Laser 230z
What are the rules in the US for night flight?
Night Walrus power setup question
I received the new Night Walrus I ordered last week from HK. I have been doing my usual detailing/ reworking prep for assembly.
I noticed the outrunner brushless motor installed in mine has a label on the motor bell that says 2215-1100KV. Everywhere I look it says that the old Walrus and the new Night Walrus comes with a 2212-1350KV motor. Mine has an AeroStar 30 ESC and the 9x? folding prop. On a bench run, I'm getting 200 watts at 17.6 amps and 11.4 volts on a 3s 2200mah LiPo. That is a respectable 110 watts/lb which seems about right for a powered sailplane. However, if they did intend to have a 1350KV motor powering this plane, the extra 2000-3000 RPM it would be twisting the prop certainly stands to produce a bunch more watts unless there was a prop change made too. Anyone out there have any vintage Walrus where they can see what motor it has? |
This is from the AMA safety code under B. Radio Control(RC)
8. RC night flying requires a lighting system providing the pilot with a clear view of the model’s attitude and orientation at all times. Hand-held illumination systems are inadequate for night flying operations. |
Rebuilding the Night Walrus
Fyathyrio, I guess you aren't the only "A/C" out there because you zeroed in on many of the shortcomings I noticed as I planned how to put this together.
The triple boxing is amusing but I read how many of the early Walrus' suffered from shipping box damage. Mine came without even a nick on the outer box. The parts seemed restrained in the box well enough but only the fuselage was immobilized, everything else "floats" around in their plastic bags. At least the wing servo horns were turned in so they didn't poke anything else. In no way would this plane be one you'd want to have to tear down to transport. Toss that idea from the get-go and try to work on some of the more critical shortcomings. The battery mounting is very untidy. You have recognized that the ESC is going to have to stand along one side of the cockpit. I think most people are standing the battery on edge between the tail servos. For the sake of good fit this probably still calls for some guide rails, Velcro and tie strap to fashion an appropriate battery tray arrangement. A fair amount of wiring will have to go behind the battery pack, so I'd cringe to think of stuffing a receiver back in there as well. I my case, I'm intending to use an OrangeRx 6-Ch Rx with builtin 3-axis stabilization so I need a solid deck to mount and orient the Rx. Also need to be able to reach and adjust the gain pots. You are right that this plane cries out for an access hatch. My choice is going to be in the belly behind the plastic skid pan back to the rear exit vent hole. My wing tips were curled up as well. They are pretty thin and weak for the last inch or two. I embedded a length of CF rod in the edge to toughen them up. They also did a sloppy job cutting the decal stickers on the wing over the flap and aileron hinges. Apparently a wavy cut is as good as a straight one for this. I was disappointed to see how they addressed the covering of the servo pockets in the wings. The tape job was pretty lame considering they went to the trouble of having a recess molded around the pockets to inlay a more substantial cover. However, they glued the servos into the pockets with a big gob of glue so they didn't lay down flush with the surrounding recess. I yanked out all the servos and re-glued them with something that wasn't so gloppy. I then cut some covers out of 0.5 mm plastic sheet and glued them into the recesses over the servos. As a finishing touch (which I do on most all my foam planes) I put a 3/4" wide strip of clear tape over the leading edge after sanding away any mold flash off the radius of the leading edge. I think you can see this isn't a simple "tonight" project for me either. I'm sure I'll develop some more tweaks as the project progresses. |
Doublecheck your Servos!!!
Had a frontal dive down crash on first flight.
After inspection of the wreck, the elevator-servo became lose. It was fixed only with some sort of thin doublesided tape. So reglue them in or better directly replace them! Other things: The rudder servo didn't center well, left turn is ok but right always offcenter. My motor is labeled Aerostar 1100KV not 1350 (see upper post). My Walrus had more power on the sticks. I extended the LED-wire for the canopy . The plastic nuts for the wings screws in the fuselage can be pressed down or one was completely missing (can't find the nut for the rear screw). The ESC is getting warm, when checking on the bench, without motor running. I won't remove the wings for transport. The wires are very short. Just my two cents Chris |
