Jun 28, 2016, 09:55 AM
Matek HUBOSD H, X & SE w/STOSD8 Thread
General
  • Input voltage range (3S-5S operation): 8 - 21VDC
  • PDB: 4x30A (Max.4x35A)
  • Regulated 5V and 12V outputs
  • Current Sensor 140A
  • Built-in STOSD8
  • Physical:
- 2oz copper, 4-layers &1.6mm PCB.
- 1x Battery input, 4x ESC outputs. 2x BEC 5V outputs, 2x BEC 12V outputs.
- Camera signal & Gnd pads, Video Transmitter Signal & Gnd pads
- 1x Serial port (RX, TX, G)
- Dimensions: 46x36x4mm, Weight: 8.5g
- Mounting holes 30.5mm square spacing,Φ3mm
More info
H Type 46*36mm, http://www.mateksys.com/?portfolio=hubosd8-h
X Type 36*36mm with XT60 mounting http://www.mateksys.com/?portfolio=hubosd8-x
SE 6S version http://www.mateksys.com/?portfolio=hubosd8-SE
STOSD
www.stosd.com
Firmware updates
HUBOSD8-H & X http://www.stosd.com/?p=726
HUBOSD8-SE http://www.stosd.com/?p=887
"Boot Loader mode" under the STOAD website.
1. Connect the TTL (RX-TX, TX-RX, G-Gnd)
2. Plug TTL-USB into computer
3. Open the STOSD8 Tool, Choose the COM port of USB-TTL. DO NOT Click "Connect", Load Firmware Local or online
4. Click "YES"
5. "Uploading..." will display 3 seconds.
6. Power on the HUBOSD with LiPo within 3 seconds. The firmware will be loaded automatically
LOW ESR Capacitors
  • Rubycon ZLH, ZLG, ZLQ series,
  • Panasonic FM or FR series,
  • Nippon Chemi-con KZM series.
  • Nichicon UHV series.
Jun 28, 2016, 01:42 PM
FPV Surfer
aerosurfer's Avatar
Please create a XT60 version of this PDB.
- Is the USB adapter for flashing firmware included?
- Why no linear regulator on the 5V BEC?
- Do you care about doing a review for this OSD? I'd publish it at http://www.aerosurfer.ch.
Jun 28, 2016, 08:53 PM
USB adapter is not included.
Linear 5V, current is not enough & very hot.
Jun 30, 2016, 08:29 AM
ufoDziner's Avatar
If only it were 6s capable. :-/
Sent from my Passport using Tapatalk
Jul 02, 2016, 06:50 PM
FPV Surfer
aerosurfer's Avatar
Any plans on a XT60 version? Basically this board with the same OSD?
I'd buy 10 of them straight away!
Jul 04, 2016, 09:48 PM
Where can I buy this
Jul 05, 2016, 03:54 AM
any feedback on this ?
Jul 05, 2016, 05:33 AM
raumagent's Avatar
This board looks promising. Is the 5V/12V output filtered?
Jul 05, 2016, 08:34 AM
12V regulator has linear output so it's meant for camera and vtx. It provides some sort of filtering but the best way is adding a low ESR capacitor where battery leads are soldered on That completely removes any noise.
Jul 05, 2016, 08:56 AM
raumagent's Avatar
Yea but what about voltage spikes due to aggressive braking? Also other boards have filtering build in...
I'm still looking for that one PDB/OSD board that makes everything right out of the box.
Jul 05, 2016, 08:57 AM
I just wanna know where to buy. Looks like the rrosd and powerosd pro has some competition. I already like this 1 better I only have high power setups and this thin.g can handle 140a that's very impressive
Jul 05, 2016, 11:20 AM
Ordered one from AliExpress, $16 delivered to UK. Now the wait begins!
Jul 05, 2016, 09:12 PM
That's what low ESR cap is exactly for. To reduce any kind of voltage spiking. Please watch this video and you'll know everything about FPV video noise filtering
Recursion Labs - Little Bee ESC Extreme Motor Noise Generation and Filtration Testing for FPV (17 min 14 sec)
Sent from my SM-G920F using Tapatalk
Jul 06, 2016, 02:01 PM
raumagent's Avatar
After watching that video I'm definitely sold on caps but still, I would wish for a board that has good filtering build in and doesn't require me to add an additional cap.
I used TBS PNP50's in the past and they have excellent filtering build in. Although they have a larger form factor and are more heavier, that's why I switched to RROSD's for now.
I'm aware that there are some technical difficulties to be solved before we see a board that "makes everything right" [TM] but I'm sure it will come out some day and that's what I am waiting for.
Jul 07, 2016, 04:52 AM
aka RCFlyer85
Irock1985's Avatar
Also would like to know where to buy to get out the fastest to the US?
