Aug 30, 2004, 01:07 AM
PGR
PGR
Low AltiDude
PGR's Avatar
Originally Posted by KillerWatt
Maybe i just didn't push 'em on hard enough but the smaller LHS 032 and GWS 037 wires seemed to fit the stock control horn and servo holes better....... kw
If you want TRICK, replace the steel music wire with titanium alloy TIG welding wire. The weight reduction is profound and the titanium doesn't rust. It's all I use for pushrods anymore.
Be prepared to spend as much as $10 for 36" stick of .032-.040, though. Thicker is even more expensive.
Pete
Aug 30, 2004, 09:05 AM
Closed Account
The control rod wire fit fine on my connectors, the only customizing I had to do was with getting the connector bottom pin into the servo arm hole. I "drilled" the servo arm hole out a little bigger with a small jewelers philips screwdriver tip, fits OK now.
Apr 11, 2017, 03:47 PM
☆ OVERDISCHARGE MASTER ☆
Flying Pitcher's Avatar
why does it keep switching me to this thread when i hit "post quick reply" in Mike ??
Happened 2 3 times now!!
Apr 14, 2017, 06:09 PM
stemo99's Avatar
.047's right here.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXJGT8
Aug 30, 2019, 01:45 AM
Check my blog....
Calcifer's Avatar
Just did it to me too? From thread 'Mike'
Aug 30, 2019, 03:02 AM
From the Dubro web site, it appears that Dubro has several sizes of both part types
Oct 07, 2019, 09:11 AM
I was just posting a reply to Mike. How did I get redirected here?!
Edit: it keeps happening. I just reproduced it again.
Oct 08, 2019, 05:49 AM
Check my blog....
Calcifer's Avatar
Maybe it is a conspiracy?
Oct 12, 2019, 03:45 PM
Genius man
denis747's Avatar
I just got redirected here too. The Matrix is everywhere!
Oct 12, 2019, 05:50 PM
Ah ha! Chihuahuas!!
Mini-HowTo My list and links of Slow Stick Mod's for A/P CactusJackSlade Aerial Photography 2 May 03, 2008 04:15 PM
Mount micro servos on slow stick 600Burger Beginner Training Area (Aircraft-Electric) 12 Jan 19, 2005 08:28 AM
Slow Stick with Sub Micro Servo Question DaGuy Parkflyers 9 Nov 07, 2004 10:21 AM
Yippee! Cheap, EZ, adjustable down and right motor mount for Slow Stick CactusJackSlade Beginner Training Area (Aircraft-Electric) 5 Mar 16, 2004 06:31 PM
slow stick links firstdegree Parkflyers 1 Aug 18, 2003 04:50 AM
