This thread is privately moderated by scousethief, who may elect to delete unwanted replies.
Jun 27, 2016, 07:03 AM
Quad Erat Demonstrandum
scousethief's Avatar
UFOFPV V3 5.8G 40CH 5 Inch 800 x 480 HD Screen FPV Goggles
http://www.banggood.com/UFOFPV-V3-5_...html?utmid=796
Brand: UFO
Screen size:5"
Max Charge Rate: 1c
Lens type: fresnel lens
Antenna connector: SMA Female
Battery weight: 75g
Weight: 320g (not excluding battery)
Current consumption:[email protected]
Dimension (mm):158x155x105
Working temperature: 0C-50C
Work time: more than 120 minutes
Supply voltage:1600mah 7.4V Li-po with power display
Screen resolution:800x480HD with intensity control, contrast control on buttons
Frequency channel: build in two 40 channel 5.8GHz A/V receiver module with racing band module
Feature:
1. Myopia below 500no need to wear glasses
2. Compatible with all system (NTSC and PAL) standard Video signal
3. Very high comfort, Breathe freely, can replace the face sponge, more comfortable
4. Adjustable straps: settled 3 point fillet can reduce the pressure of long time wear to the head
5. The new FPV goggles was designed from the ground up with the FPV racing pilot in mind, with quality, performance and comfort at the forefront. The goggles gently rests on the forehead/cheeks spreading the weight out evenly, which compared to many video goggles which rest on the bridge of the nose instead.
Presale price 68.38/$89.99
