This thread is privately moderated by Jack Crossfire, who may elect to delete unwanted replies.
Jun 26, 2016, 07:55 PM
Jack Crossfire's Avatar
Feiyu current vs PWM
The last experiments with The Feiyu involved feeling the amount of torque as the phase changed. This revealed the torque dropping to 0 & the motor stalling exactly where there was a glitch in the current sensed by the resistors. That was where the current of a phase reversed direction or where the PWM on any of the phases crossed halfway.
The next step was holding 1 phase at a constant PWM while ramping a 2nd phase from 0 to the 1st phase. The 3rd phase was disconnected. This started with strongly negative current through the current sense resistor. The current approached 0 as the 2 phases got closer.
This revealed the same glitch when the variable PWM started approaching the fixed PWM & 0 current. It was more clear that the current approached 0 faster than it should have as the PWM increased, then leveled off until it hit 0.
Tried the 2 phase test with different values of the constant PWM. That varied the point of inflection in the variable current to match where the stationary PWM was.
