Jun 25, 2016, 12:52 PM
Can Polyurethane paints be used on wooden RC boat models?
I've recently come into possession of a Dumas #88 'Crockett' RC boat. I've been cleaning it up and adding some minor details. I'd like to freshen-up the exterior hull using Minwax FAST-DRYING Polyurethane clear satin spray paint. (UPC code: 27426 33060). The can says "Interior Use Only". Can I use it on the outside of the hull without any problems? Thanks for your advice!
Regards, Randy Griggs
Jun 25, 2016, 01:17 PM
"Interior" implies inside, not exposed to weather, and possibly limited exposure to the sun. It should work fine, as long as you are placing the model on a shelf, in your house, or a museum. If on the other hand, you want to put the model in a lake/pond and run it, I would suggest using a different paint specified for exterior use.
Jun 25, 2016, 02:11 PM
Interior implies that there are no UV protectors in the varnish and it will change color going to yellow in direct sunlight. Also there is a difference in the adhesion in interior since it does not have to put up with varying moisture and sunlight.
Jun 27, 2016, 03:16 AM
No direct sunlight on interior woodwork is a very rash assumption. The south facing inside windows & window ledges are by far the hottest bits of wood in our house from direct sunlight. I understand that UV passes through glass just as it does through water.
I had always thought that "interior" was to do with its weather fastness rather than its uv protection.
You live & learn.
