This thread is privately moderated by GottaZoom, who may elect to delete unwanted replies.
Jun 22, 2016, 05:05 PM
Up! Up! And Away!
GottaZoom's Avatar
Data
Delta Ray brushless prop tests
Props to be tested as follows:
Electronics
- Hobbymate 2204 motor mounted to Delta Ray fairing
- Afro 20A Race Spec Mini ESCs, DR edition BLHeli firmware
- Modified OEM Delta Ray RX (oem ESCs removed, main cap upgraded)
. 3S 25C 1200mAh battery, freshly charged for each test
Propellors, 4 blades
- HQ 5x4x4
Propellors, 3 blades
- Gemfan 5030x3
Propellors, 2 blades
- Lantian 6045
- HQ C6x30
- Gemfan 6030
- HQ C5x30
- DTI 5030 (ghost)
Jun 22, 2016, 05:10 PM
Up! Up! And Away!
GottaZoom's Avatar
Trying to measure thrust using a scale with the lightweight fairings was a fail. My only semi-successful attempt with the HQ 4 blade prop showed a little over 540g of thrust, but I suspect some error as I had to hold the fairing stable due to torque and lift.
Thrust measurements will be attempted again after the plane is built.
Jun 22, 2016, 06:04 PM
Up! Up! And Away!
GottaZoom's Avatar
Watts/Amps/Propellor - 1 motor, 3S
- 127 / 11 HQ 5x4 4-blade
- 074 / 06 Gemfan 5x3 3-blade
- 132 / 11 Lantian 6045
- 099 / 09 HQ C6x30
- 106 / 09 Gemfan 6030
- 077/ 06 HQ C5x30
- 068 / 06 DTI 5030 (ghost)
Watts/Amps/Propellor - 1 motor, 2S
- 054 / 06 Lantian 6045 (to be redone with fully charged battery)
Jun 22, 2016, 06:06 PM
Up! Up! And Away!
GottaZoom's Avatar
Candidates for testing
26 Jul 2016
* NEW props added to the list above.
Propellors, 6 blades
- Gemfan 5x4x6*
- HQ 5x4x4
- Gemfan 5030x3
- HQ 5x4x3*
- Lantian 6045
- HQ C6x30
- Gemfan 6030
- HQ 5x4.5*
- HQ C5x30
- DTI 5030 (ghost)
Jul 27, 2016, 01:02 AM
Up! Up! And Away!
GottaZoom's Avatar
Prop tests - 2 motors combined
26 Jul 2016
Watts and Amps are peak readings from meter
Thrust was observed, read in pounds and converted to grams
Power system:
- Hobbymate 2204 motors
- HK Afro 20A Race Spec Mini ESCs, flashed with DR Edition of BLHeli firmware
- Throttle signals from Delta Ray RX
Many thanks to friend who loaned me their gear to do these tests.
Please note that the data below if offered for evaluation, it is not a suggestion that any measured power level is safe for these, or similar, motors. Please refer to your manufacturer's specifications.
Data
Thrust(lb) / Thrust (g) / Watts / Amps / Prop
3S 25C 1200mAh
1.61 / 730 / 241 / 21.4 / HQ 6x4.5x2 (*)
1.56 / 708 / 249 / 21.8 / Gemfan 5x4x6 (*)
1.21 / 549 / 184 / 16.3 / HQ 5x4x3
1.05/ 476 / 131 / 11.0 / Gemfan 5x3x3
1.03/ 467 / 130 / 10.9 / DTI 5x3x2
2S 20C 1500mAh
0.74 / 336 / 097 / 12.3 / Lantian 6x4.5x2
0.70 / 317 / 100 / 13.0 / Gemfan 5x4x6
(*) ESCs hit LVC? (default setting appears to be 3.4v/cell in DR modified BLHeli firmware)
Jul 27, 2016, 10:26 AM
Up! Up! And Away!
GottaZoom's Avatar
Prop tests, continued - 2 motors combined
27 Jul 2016
Same process and equipment as in post #5 above, however please note the Lantian prop rerun shows thrust was higher than yesterday. Not sure if this is due to the equipment reset, or atmosphere, or simply running throttle a bit longer. As a result the data is not combined.
Data
3S 25C 1200mAh
1.56 / 708 / 161 / 13.9 / HQ C6x3x2
1.54 / 699 / 170 / 14.7 / GF 6030x2
1.52 / 689 / 222 / 19.6 / HQ 5x4x4(*)
1.23 / 558 / 170 / 14.4 / HQ 5x4.5x2
2S 20C 1500mAh
0.81 / 367 / 093 / 12.1 / Lantian 6x4.5x2
0.77 / 349 / 091 / 11.7 / HQ 5x4x4
0.72 / 327 / 065 / 08.4 / HQ C6x3x2
0.68 / 251 / 065 / 08.3 / GF 6030x2
